查看: 1678|回复: 0
[CFD及热分析] ansys导线短路温度场仿真出现了负值
发表于 2013-3-19 14:39 | 显示全部楼层 |阅读模式
ansys温度场求解时温度出现了负值或低于最初的设定值(20℃)
我的模型是两根铜导线搭接到一起,中间短路点被碳化(选用炭材料)导线外有绝缘皮。给导线通短路电流,并计算产生的温度场。
在求解计算时,我不加绝缘皮(只有两根铜导线和中间的炭化点)时不存在温度降低的情况,可是加上绝缘皮后就出现了负值的温度点。
不知道是什么原因,有人说是网格不够细致,可是我细化了网格后还是不行,不知道是不是边界加的有问题。
绝缘皮用加边界条件么,不知道怎么修改了。请求给位ansys高手的帮助,感激不尽~
程序
FINISH
/CONFIG,NRES,100000
/PREP7
ET,1,SOLID69
MP,DENS,1,8900
MPTEMP,,,,,,,,
MPTEMP,1,20,127,327,527,827,1027
MPTEMP,7,1083,1127,1227,1527
MPDATA,RSVX,1,1,1.678E-8,2.402E-8,3.792E-8,5.262E-8,7.551E-8,9.101E-8
MPDATA,RSVX,1,7,12.237E-8 ,13.147E-8,14.613E-8,19.414E-8
MPTEMP,,,,,,,,
MPTEMP,1,20,100,300,500,900,1083
MPTEMP,7,1200,1500,1800,2200,2700,3000
MPDATA,C,1,1,380,394,410,428,474,520
MPDATA,C,1,7,533,545,556,575,598,612
MPTEMP,,,,,,,,
MPTEMP,1,20,77,127,227,327,527
MPTEMP,7,727,927
MPDATA,KXX,1,1,403,396,393,386,379,366
MPDATA,KXX,1,7,352,339
MPTEMP,,,,,,,,
MPTEMP,1,20,1072,1084,1200,1600,2000
MPTEMP,7,2586,2596,2900
MPDATA,ENTH,1,1,0,3.5579E9,2.5329E10,2.358E11,9.6149E11,1.687E12
MPDATA,ENTH,1,7,2.725E12,3.149E12,3.165E12
MP,DENS,2,1870
MP,RSVX,2,0.0000012
MP,KXX,2,400
MPTEMP,,,,,,,,
MPTEMP,1,20,100,300,500,900,1200
MPTEMP,7,1800,2100,2300,2500,2700,3000
MPDATA,C,2,1,645,1020,1323,1604,1901,2010
MPDATA,C,2,7,2152,2211,2248,2290,2338,2401
ET,2,SOLID90
MP,DENS,3,1380
MP,KXX,3,100
MP,C,3,1580
MP,RSVX,3,10E11
建模
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
CYLIND,0.00089,0,0,0.025,0,360,
wpoff,,,0.0245
wpro,,,90.000000
BLOCK,0.0005,,0.0005,,0.0032,,
wpro,,,-90.000000
wpoff,0.0035,,-0.001
VSBV, 2, 1
VSBV,4,3
CYLIND,0.00089, ,0,0.025,0,360,
wpoff,-0.0035,,-0.0235
CYLIND,0.00169, 0.00089,0,0.023,0,360,
wpoff,0.0035,,0.0255
CYLIND,0.00169,0.00089 ,0,0.023,0,360,
VGLUE,ALL
NUMCMP,ALL
VSEL,S,,,4
VSEL,A,,,5
VATT,1, ,1, 0
VSEL,S,,,1
VATT,2, ,1,0
VSEL,S,,,2
VSEL,A,,,3
VATT,3, ,2, 0
网格划分
LSEL,S,,,1
LSEL,A,,,2
LSEL,A,,,5
LSEL,A,,,7
LSEL,A,,,63
LSEL,A,,,65
LESIZE,ALL,,,10
LSEL,S,,,29
LSEL,A,,,30
LSEL,A,,,31
LSEL,A,,,32
LSEL,A,,,3
LSEL,A,,,4
LSEL,A,,,8
LSEL,A,,,6
LESIZE,ALL,,,3
LSEL,S,,,62
LSEL,A,,,64
LESIZE,ALL,,,2
LSEL,S,,,19
LSEL,A,,,22
LSEL,A,,,39
LSEL,A,,,18
LSEL,A,,,23
LSEL,A,,,38
LSEL,A,,,20
LSEL,A,,,21
LSEL,A,,,40
LSEL,A,,,17
LSEL,A,,,24
LSEL,A,,,37
LSEL,A,,,11
LSEL,A,,,14
LSEL,A,,,48
LSEL,A,,,12
LSEL,A,,,13
LSEL,A,,,47
LSEL,A,,,10
LSEL,A,,,15
LSEL,A,,,49
LSEL,A,,,9
LSEL,A,,,16
LSEL,A,,,50
LESIZE,ALL,,,8
LSEL,S,,,27
LSEL,A,,,28
LSEL,A,,,33
LSEL,A,,,34
LSEL,A,,,26
LSEL,A,,,35
LSEL,A,,,25
LSEL,A,,,36
LSEL,A,,,45
LSEL,A,,,52
LSEL,A,,,46
LSEL,A,,,51
LSEL,A,,,44
LSEL,A,,,53
LSEL,A,,,43
LSEL,A,,,54
LESIZE,ALL,,,14
LSEL,S,,,41
LSEL,A,,,42
LSEL,A,,,57
LSEL,A,,,58
LSEL,A,,,55
LSEL,A,,,56
LSEL,A,,,59
LSEL,A,,,60
LESIZE,ALL,,,57
ALLSEL
VSWEEP,5,8,9
VSWEEP,4,6,7
VSWEEP,3,14,22
VSWEEP,2,10,19
VSWEEP,1,2,4
求解计算
/SOLU
ANTYPE,TRANS
TIMINT,ON
TUNIF,20
AUTOTS,ON
ASEL,S, , , 7
NSLA,S,1
D,ALL,VOLT,0
ASEL,S, , , 8
NSLA,S,1
CP,1,VOLT,ALL
NI=NDNEXT(0)
ALLSEL
T=1E-8                 设置开始求解时间
DL=600                电流有效值
TZ=0.01                结束时间
N=100                 一个周期的步数
F=50                  频率
PI=2*ASIN(1)          获得π值
CON=1/F/N            设置时间步长
NEQIT,1               设置时间步的迭代次数
*CREATE,LOAD        创建宏设置载荷步
TIME,T                设置载荷步时间
I=DL*1.414*SIN(2*PI*F*T)        计算激励电流
F,NI,AMPS,I             加载电流
T=T+CON              时间递增
SOLVE
*END                   结束宏命令
*DO,I,1,TZ/CON+1        循环命令
*USE,LOAD           执行宏
*ENDDO                结束循环命令
FINISH
/POST1
SET,LAST
PLNSOL,TEMP
GMT+8, 2025-1-9 14:49 , Processed in 0.053264 second(s), 18 queries , Gzip On.
