查看: 2899|回复: 2
[Patran专区] patran读入proe模型出问题了
发表于 2013-3-7 23:03 | 显示全部楼层 |阅读模式
偶尝试用patran  import某一个装配体进行前处理,可是系统提示: The executable "xplus_proep.exe" does not exist.  Please contact your MSC.Software representative for details on how to obtain this executable.
这个该怎么解决啊?还有读入igs 格式的也是这样?该怎么办?
 楼主| 发表于 2013-3-7 23:20 | 显示全部楼层
上面这个问题偶解决了,可是开始读入后,又出现提示:“The Pro/ENGINEER to Parasolid translator failed to generate a Parasolid Transmit file to import.  An alternative approach to consider using would be to turn off "Import to Parasolid" toggle on the import form and try again.”
但是我不想用Parasolid这个中介,就想直接读入proe模型,怎么办?
 楼主| 发表于 2013-3-7 23:34 | 显示全部楼层
http://forum.vibunion.com/forum.php?mod=viewthread&tid=11782
这个帖子尝试了,没解决偶的问题!
GMT+8, 2024-12-29 03:28 , Processed in 0.102371 second(s), 17 queries , Gzip On.
