查看: 1673|回复: 1
[电磁场分析] 3D螺旋线圈周围空气区域网格剖分
发表于 2013-2-22 15:30 | 显示全部楼层 |阅读模式
3D螺旋线圈被包围在立方体空气区域中,单元类型均为solid122,对空气区域网格划分总是失败,望指教,谢谢!下附命令流:
/clear
/prep7
*set,a,19
*set,b,5.43
*set,c,20
*set,d,0.8
*AFUN,DEG
*do,i,0,20*a
*set,x,c*cos(18*i)
*set,y,c*sin(18*i)
*set,z,i/b
k,i+1,x,y,z
*enddo
*AFUN,RAD
*do,i,1,20*a-4,5
bsplin,i,i+1,i+2,i+3,i+4,i+5
*enddo
FLST,2,76,4,ORDE,2
FITEM,2,1
FITEM,2,-76
LCOMB,P51X, ,0
kwpave,1
LWPL,-1,1,0
pcirc,d,,0,360
VDRAG,       1, , , , , ,       1
WPCSYS,-1,0
wpoff,,,-5
BLOCK,-25,25,-25,25,0,80,
GPLOT
/PREP7
FLST,2,1,6,ORDE,1
FITEM,2,2
FLST,3,1,6,ORDE,1
FITEM,3,1
VSBV,P51X,P51X, , ,KEEP
ET,1,SOLID122
KEYOPT,1,4,0
KEYOPT,1,5,0
KEYOPT,1,6,0
KEYOPT,1,7,0
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,1,,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,RSVX,1,,0.0175e-6
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,2,,1
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       1, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , ,       3
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       2, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
SMRT,6
SMRT,8
/UI,MESH,OFF
MSHAPE,1,3D
MSHKEY,0
 楼主| 发表于 2013-2-25 10:31 | 显示全部楼层
加上最后一句vmesh,3,自由剖分运行半小时都没完,改用手动剖分,设置LESIZE运行结束显示错误:
vmesh failure,perhaps due to:
(1)poorly shaped triangular facets:mesh area with triangular elements,modify mesh control or turn on smartsizing to get good triangular mesh,then vmesh again。
(2)complex geometry:subdivide volume&try again
GMT+8, 2025-1-10 06:18 , Processed in 0.061716 second(s), 18 queries , Gzip On.
