查看: 1342|回复: 0
[线性振动] 关于Multi-Point Response Spectrum
发表于 2012-12-30 15:59 | 显示全部楼层 |阅读模式
反映谱分析包括Single-Point Response Spectrum (SPRS) 和Multi-Point Response Spectrum (MPRS)。
In a single-point response spectrum (SPRS) analysis, you specify one response spectrum curve (or a family of curves) at a set of points in the model, such as at all supports,
In a multi-point response spectrum (MPRS) analysis, you specify different spectrum curves at different sets of points。
如果地震谱在三个方向都有,且不同,但作用于一个节点上,还算是Multi-Point Response Spectrum (MPRS)吗?谢谢指导!
GMT+8, 2024-11-29 07:59 , Processed in 0.050837 second(s), 17 queries , Gzip On.
