查看: 1460|回复: 2
[其他相关] 夹层结构振动模态及阻尼分析
发表于 2012-12-19 14:07 | 显示全部楼层 |阅读模式
我做的频率
  *****  INDEX OF DATA SETS ON RESULTS FILE  *****
   SET   TIME/FREQ    LOAD STEP   SUBSTEP  CUMULATIVE
     1  80.769             1         1         1
     2  146.44             1         2         2
     3  228.95             1         3         3
     4  252.99             1         4         4
     5  300.62             1         5         5
     6  404.11             1         6         6
     7  419.99             1         7         7
     8  483.93             1         8         8
     9  568.42             1         9         9
    10  590.32             1        10        10
最近用ANSYS分析夹层梁的模态和阻尼,照上面的例子做的下面是命令流,没在模型中加中间夹层的损耗因子(不知道算是哪个阻尼)。采用三边约束Y方向,一边全约束,block lanczos法分析的模态,为什麽频率差别较大,错在哪些地方,哪位专家给点指导呀
/BATCH
/COM,ANSYS RELEASE 10.0    UP20050718       13:51:54    12/19/2012
/PREP7
ET,1,SOLID45
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,7e10
MPDATA,PRXY,1,,0.33
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,2700
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,1.7241e6
MPDATA,PRXY,2,,0.45
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,2,,1000
BLOCK,0,0.5,0,0.002,0,0.3,
BLOCK,0,0.5,0.002,0.005,0,0.3,
BLOCK,0,0.5,0.005,0.007,0,0.3,
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
FLST,2,3,6,ORDE,2
FITEM,2,1
FITEM,2,-3
VGLUE,P51X
/VIEW,1,,,1
/ANG,1
/REP,FAST
/DIST,1,0.924021086472,1
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
FLST,5,2,6,ORDE,2
FITEM,5,1
FITEM,5,5
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       1, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , ,       4
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       2, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/AUTO,1
/REP,FAST
FLST,5,28,4,ORDE,10
FITEM,5,1
FITEM,5,-12
FITEM,5,14
FITEM,5,19
FITEM,5,23
FITEM,5,-24
FITEM,5,26
FITEM,5,31
FITEM,5,35
FITEM,5,-44
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1,0.001, , , , , , ,1
LPLOT
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
FLST,5,4,4,ORDE,4
FITEM,5,2
FITEM,5,4
FITEM,5,14
FITEM,5,26
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,20, , , , ,1
FLST,5,4,4,ORDE,4
FITEM,5,9
FITEM,5,12
FITEM,5,24
FITEM,5,36
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,4,4,ORDE,4
FITEM,5,5
FITEM,5,7
FITEM,5,19
FITEM,5,31
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,4,4,ORDE,4
FITEM,5,10
FITEM,5,-11
FITEM,5,23
FITEM,5,35
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
VPLOT
FLST,5,3,6,ORDE,3
FITEM,5,1
FITEM,5,4
FITEM,5,-5
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/UI,MESH,OFF
/DIST,1,1.08222638492,1
/REP,FAST
/REP,FAST
/REP,FAST
FINISH
/SOL
ANTYPE,2
MSAVE,0
MODOPT,LANB,10
EQSLV,SPAR
MXPAND,10, , ,1
LUMPM,0
PSTRES,0
MODOPT,LANB,10,0,0, ,OFF
OUTPR,ALL,ALL,
OUTRES,ALL,ALL,
ASEL,S,LOC,X,0
APLOT
ASEL,S,LOC,X,0
FLST,2,3,5,ORDE,3
FITEM,2,5
FITEM,2,22
FITEM,2,26
/GO
DA,P51X,ALL,
ALLSEL,ALL
ASEL,S,LOC,Z,0
APLOT
ASEL,S,LOC,Z,0
FLST,2,3,5,ORDE,3
FITEM,2,1
FITEM,2,19
FITEM,2,23
/GO
DA,P51X,UY,
ALLSEL,ALL
ASEL,S,LOC,Z,0.3
APLOT
ASEL,S,LOC,Z,0.3
FLST,2,3,5,ORDE,3
FITEM,2,2
FITEM,2,20
FITEM,2,24
/GO
DA,P51X,UY,
ALLSEL,ALL
ASEL,S,LOC,X,0.5
APLOT
ASEL,S,LOC,X,0.5
FLST,2,3,5,ORDE,3
FITEM,2,6
FITEM,2,21
FITEM,2,25
/GO
DA,P51X,UY,
ALLSEL,ALL
APLOT
/REP,FAST
/STATUS,SOLU
SOLVE
FINISH
/POST1
SET,LIST,999
SET,LIST,2
 楼主| 发表于 2012-12-19 14:09 | 显示全部楼层
尤其是高阶模态差距更大了
 楼主| 发表于 2012-12-19 14:16 | 显示全部楼层
网格划分厚度方向1毫米,长宽都是划分20份
GMT+8, 2025-1-10 02:21 , Processed in 0.061092 second(s), 22 queries , Gzip On.
