查看: 1518|回复: 4
[结构分析] ansys在做瞬态分析是出现错误
发表于 2012-12-7 11:00 | 显示全部楼层 |阅读模式
ansys在做瞬态分析是出现错误,网格重新划分后还是不行(也可能是划分后的网格还是不行)。而有的相似模型操作也一样却没问题,求大侠们指导。
One or more elements have become highly distorted.  Excessive
distortion of elements is usually a symptom indicating the need for
corrective action elsewhere.  Try incrementing the load more slowly
(increase the number of substeps or decrease the time step size).  You
may need to improve your mesh to obtain elements with better aspect
ratios.  Also consider the behavior of materials, contact pairs,
and/or constraint equations.  If this message appears in the first
iteration of first substep, be sure to perform element shape checking.
发表于 2012-12-11 13:07 | 显示全部楼层
好像还是网格划分的问题。
 楼主| 发表于 2012-12-12 11:29 | 显示全部楼层
发表于 2012-12-12 11:35 | 显示全部楼层
通体提示来看可能是个别单元位移过大,造成了单元过度的扭曲
可能原因:
1、 材料刚度过小
2、 网格的尺寸不合理
3、子步太少
等,都调调吧
 楼主| 发表于 2012-12-12 15:38 | 显示全部楼层
可能原因:
1、 材料刚度过小
哦  我再试试吧
GMT+8, 2025-1-10 02:58 , Processed in 0.062681 second(s), 17 queries , Gzip On.
