查看: 7320|回复: 6
[分形与混沌] 求排列熵的matlab源程序?
发表于 2012-12-3 21:57 | 显示全部楼层 |阅读模式
本人需要求出手上脑电数据的排列熵,哪位大侠能赐教排列熵的matlab源程序?
发表于 2012-12-5 01:10 | 显示全部楼层
  1. function [pe hist] = pec(y,m,t)
  2. %  Calculate the permutation entropy
  3. %  Input:   y: time series;
  4. %           m: order of permuation entropy
  5. %           t: delay time of permuation entropy,
  6. % Output:
  7. %           pe:    permuation entropy
  8. %           hist:  the histogram for the order distribution
  9. %Ref: G Ouyang, J Li, X Liu, X Li, Dynamic Characteristics of Absence EEG Recordings with Multiscale Permutation %     %                             Entropy Analysis, Epilepsy Research, doi: 10.1016/j.eplepsyres.2012.11.003
  10. %     X Li, G Ouyang, D Richards, Predictability analysis of absence seizures with permutation entropy, Epilepsy %     %                            Research,  Vol. 77pp. 70-74, 2007
  11. ly = length(y);
  12. permlist = perms(1:m);
  13. c(1:length(permlist))=0;
  14.
  15. for j=1:ly-t*(m-1)
  16.      [a,iv]=sort(y(j:t:j+t*(m-1)));
  17.      for jj=1:length(permlist)
  18.          if (abs(permlist(jj,:)-iv))==0
  19.              c(jj) = c(jj) + 1 ;
  20.          end
  21.      end
  22. end
  23. hist = c;
  24. c=c(find(c~=0));
  25. p = c/sum(c);
  26. pe = -sum(p .* log(p));
 楼主| 发表于 2012-12-9 10:25 | 显示全部楼层
发表于 2012-12-21 22:50 | 显示全部楼层
Multiscale Permutation Entropy (MPE)
matlabcentral/fileexchange/authors/256154
发表于 2013-7-23 10:21 | 显示全部楼层
这个程序计算时有很多冗余,在算m=7以上的排列熵时,慢得要命
发表于 2013-8-23 09:26 | 显示全部楼层
不对吧,大于1呢
发表于 2017-9-4 17:50 | 显示全部楼层
五楼说的对,计算量有点大
GMT+8, 2024-12-27 21:24 , Processed in 0.116442 second(s), 18 queries , Gzip On.
