查看: 1203|回复: 0
[非线性振动] 关于sysnoise中的peak与RMS?
发表于 2012-11-26 11:10 | 显示全部楼层 |阅读模式
RESP IR, LFTAB, LDTAB, ITYPE, RATIO, DTIME, TMIN, TMAX
——Generates a response spectrum
The response spectrum is defined as the maximum response of single degree of freedom systems of varying frequency (or period) to a given input support excitation. The equation describing the response of the system in terms of the relative displacement (X) is:
式中:ξ表示阻尼比(ratio of viscous damping to critical damping);ωn表示系统固有频率(natural frequency of the system);Xo表示ground displacement
The solution of this equation for the maximum response, ,at various frequencies results in the spectral response curve
从上面ansys中的help文件看出,通过resp得到的频域位移曲线是最大值,是peak?
如果是peak的话,那么在计算辐射噪声的时候又采用RMS,是不是矛盾了?求解释
GMT+8, 2024-11-29 08:58 , Processed in 0.072795 second(s), 21 queries , Gzip On.
