查看: 4966|回复: 2
[Maple] 矩阵的类型以及transpose的用法?
发表于 2012-11-10 19:38 | 显示全部楼层 |阅读模式
> with(VectorCalculus);
[&x, *, +, -, ., `<,>`, `<|>`, About, AddCoordinates, ArcLength,
  BasisFormat, Binormal, Compatibility, ConvertVector,
  CrossProduct, Curl, Curvature, D, Del, DirectionalDiff,
  Divergence, DotProduct, Flux, GetCoordinateParameters,
  GetCoordinates, GetNames, GetPVDescription, GetRootPoint,
  GetSpace, Gradient, Hessian, IsPositionVector, IsRootedVector,
  IsVectorField, Jacobian, Laplacian, LineInt, MapToBasis, Nabla,
  Norm, Normalize, PathInt, PlotPositionVector, PlotVector,
  PositionVector, PrincipalNormal, RadiusOfCurvature,
  RootedVector, ScalarPotential, SetCoordinateParameters,
  SetCoordinates, SpaceCurve, SurfaceInt, TNBFrame, Tangent,
  TangentLine, TangentPlane, TangentVector, Torsion, Vector,
  VectorField, VectorPotential, VectorSpace, Wronskian, diff,
  eval, evalVF, int, limit, series]
> with(LinearAlgebra);
[&x, Add, Adjoint, BackwardSubstitute, BandMatrix, Basis,
  BezoutMatrix, BidiagonalForm, BilinearForm, CARE,
  CharacteristicMatrix, CharacteristicPolynomial, Column,
  ColumnDimension, ColumnOperation, ColumnSpace, CompanionMatrix,
  ConditionNumber, ConstantMatrix, ConstantVector, Copy,
  CreatePermutation, CrossProduct, DARE, DeleteColumn, DeleteRow,
  Determinant, Diagonal, DiagonalMatrix, Dimension, Dimensions,
  DotProduct, EigenConditionNumbers, Eigenvalues, Eigenvectors,
  Equal, ForwardSubstitute, FrobeniusForm, GaussianElimination,
  GenerateEquations, GenerateMatrix, Generic, GetResultDataType,
  GetResultShape, GivensRotationMatrix, GramSchmidt,
  HankelMatrix, HermiteForm, HermitianTranspose, HessenbergForm,
  HilbertMatrix, HouseholderMatrix, IdentityMatrix,
  IntersectionBasis, IsDefinite, IsOrthogonal, IsSimilar,
  IsUnitary, JordanBlockMatrix, JordanForm, KroneckerProduct,
  LA_Main, LUDecomposition, LeastSquares, LinearSolve,
  LyapunovSolve, Map, Map2, MatrixAdd, MatrixExponential,
  MatrixFunction, MatrixInverse, MatrixMatrixMultiply,
  MatrixNorm, MatrixPower, MatrixScalarMultiply,
  MatrixVectorMultiply, MinimalPolynomial, Minor, Modular,
  Multiply, NoUserValue, Norm, Normalize, NullSpace,
  OuterProductMatrix, Permanent, Pivot, PopovForm,
  QRDecomposition, RandomMatrix, RandomVector, Rank,
  RationalCanonicalForm, ReducedRowEchelonForm, Row,
  RowDimension, RowOperation, RowSpace, ScalarMatrix,
  ScalarMultiply, ScalarVector, SchurForm, SingularValues,
  SmithForm, StronglyConnectedBlocks, SubMatrix, SubVector,
  SumBasis, SylvesterMatrix, SylvesterSolve, ToeplitzMatrix,
  Trace, Transpose, TridiagonalForm, UnitVector,
  VandermondeMatrix, VectorAdd, VectorAngle,
  VectorMatrixMultiply, VectorNorm, VectorScalarMultiply,
  ZeroMatrix, ZeroVector, Zip]
> rA := Matrix(2, 1, {(1, 1) = r*cos(theta(t)), (2, 1) = r*sin(theta(t))});
                    Matrix(%id = 5011560706)
> A := Matrix(2, 2, {(1, 1) = cos(theta(t)), (1, 2) = -sin(theta(t)), (2, 1) = sin(theta(t)), (2, 2) = cos(theta(t))});
                    Matrix(%id = 5011560770)
> `&rho;p` := Matrix(2, 1, {(1, 1) = sum(l[j], j = 1 .. i-1)+xe, (2, 1) = 0});
                    Matrix(%id = 5011560834)
> q(t):=matrix(6,1);   ;
t -> matrix(6, 1)
> type(q(t), matrix);
                              true
> qt(t):=Transpose(q(t)); ;
Error, invalid input: LinearAlgebra:-Transpose expects its 1st argument, A, to be of type {Matrix, Vector, scalar} or coercible via `~Simplify`, but received array( 1 .. 6, 1 .. 1, [ ] )
 楼主| 发表于 2012-11-10 19:39 | 显示全部楼层
为什么会出现红色所显示的错误呢?我应该怎么改呢?
我用whattype(q(t));得到的是array,为什么呢?根据红字所显示的意思,transpose命令是不适用于array数据类型的,但是用matrix这个命令出来的数据类型就是array,我该怎么办呢,是不是transpose命令不适用于matrix命令得到的矩阵呢?
发表于 2013-3-18 12:52 | 显示全部楼层
查帮助啊,有中文帮助的
GMT+8, 2024-12-27 20:28 , Processed in 0.095613 second(s), 17 queries , Gzip On.
