查看: 1803|回复: 1
[材料与接触] 在LS-DYNA的SHELL163叠层问题请教
发表于 2012-10-18 14:35 | 显示全部楼层 |阅读模式
主要现在要做一个有叠层角度90/90/0/0] S的叠层,
冲击模型试片长宽高为200毫米* 50MM * 1.2MM,做一种钢球自由落下
冲击分析,使用元素是SOLID164跟SHELL163
在SHELL163不知道如何设定叠层角度及设定方法
以下是我所写的程式:
FINISH
/CLEAR,START
/CONTOUR,1,128
/eshape,1
!*****DefineParameters*******
pi =ACOS(-1)  !pi=3.14
Leng=0.2                      ! 冲击试片尺寸
Wide=0.05
High=0.0012
Th=0.00015
BBB=0.138                          !冲击高度ballsize=0.03808                   ! 钢球直径
/PREP7
!***** ELEMENTTYPE *****
ET,1,shell163
ET,2,solid164
!*******TC12K35/EPO-AIMP材料性质********
R,1,5/6,,high
MPTEMP,1,0                      !AL
MP,EX,1,129.86e9
MP,EY,1,7.71e9
MP,EZ,1,7.71e9
MP,PRXY,1,0.33
MP,PRYZ,1,0.33
MP,PRXZ,1,0.33
MP,GXY,1,3.45e9
MP,GYZ,1,3.45e9
MP,GXZ,1,3.45e9
MP,DENS,1,1700
TB,PLAW,,,,1
TBDATA,1,270E6                   !*Yield Strength
TBDATA,2,1.35E8                  !*E2
TBDATA,4,6500.0                  !*! C (s-1)
TBDATA,5,4.0                     !*P
TBDATA,6,0.17                    !*Failure Strain
!*************** 钢球材料性值******************
MP,EX,2,200e9
MP,PRXY,2,0.3
MP,DENS,2,7847
!******************* 板建模*********************
k,1,0,0,0
k,2,leng,0,0
k,3,leng,0,-Wide
k,4,0,0,-wide
a,1,2,3,4
TYPE,1
MAT,1
REAL,1
LSEL,S,LOC,x,0
LSEL,A,LOC,x,leng
LEsize,all,,,10
ALLSEL
Amesh,all,all
LOCAL,15,0,,,,,-90
wpcsys,15
!*******************球建模*********************
WPOFFS,Leng/2,wide/2,BBB+ballsize/2
SPH4,0,0,ballsize/2
WPROTA,,90,
VSEL,S,,,1
type,2
MAT,2
ESIZE,,5
ASEL,ALL
MSHAPE,1,3D
MSHKEY,0
VMESH,1
wpcsys,15
WPROTA,,90,
ALLSEL
CM,allnode,NODE
ASEL,S,,,1
NSLV,S,1
CM,BEAM,NODE
ALLSEL,ALL
ASEL,S,,,2,3
NSLV,S,1
CM,CUBE,NODE
ALLSEL,ALL
!*** Contact***
EDCGEN,ASTS,CUBE,BEAM,,,,,,,,,,0,1E7
FINISH
/SOLU
ALLSEL
!***BOUND ***
NSEL,all
NSEL,S,LOC,x,Leng
NSEL,A,LOC,x,0
D,ALL,ALL
NSEL,all
ALLSEL
!*** InitialVelocity ***
EDVEL,VELO,CUBE,0,0,0,0,0                    !EDVEL or EDPVEL
!*** 时间及加速度之定义 ***
*DIM,TIME,ARRAY,2,1,1
*DIM,GY,ARRAY,2,1,1
*SET,TIME(1,1,1),0.0             !*time_start
*SET,TIME(2,1,1),0.7            !*time_end
*SET,GY(1,1,1),9.81
*SET,GY(2,1,1),9.81
!*** Specifiesloads for an explicit dynamics analysis. ***
EDLOAD,ADD,ACLY,0,allnode,TIME,GY,0
!*** LS-DynaSET ***
TIME,0.7
EDRST,100
EDHTIME,100
!EDHIST,ALLNODE
EDDUMP,1
EDENERGY,1,1,1,1
EDOPT,ADD,BLANK,BOTH
EDOUT,ALL
EDWRITE,BOTH,'FILE','K',''
SAVE
EDRUN,SMP,1,2
SOLVE
FINISH
n_number=NODE(leng/2,Wide/2,0)
!*** POSTSetting ***
/POST1
/DSCALE,1,1.0
SET,LAST
PLNSOL,U,Y,0,1.0
/POST26
NSOL,2,81,U,Y,Uy
PLVAR,2,
*GET,UYNODE,NODE,n_number,u,y
!/POST1
!/DSCALE,1,1.0
!SET,LAST
!PLNSOL,S,EQV,0,1
!/POST26
!NSOL,2,NODE(1,0.5,0),U,Y,Uy
!NSOL,3,NODE(1.5,0,0),U,Y,Uy
!DERIV,4,2,1,,Vy,,,1
!DERIV,5,3,1,,Ay,,,1
!PLVAR,3
希望使用SHELL163的叠层问题能解决,在程式中有什么问
题麻烦帮我解答,感激
发表于 2012-10-18 14:58 | 显示全部楼层
发帖辛苦了,楼主 支持
GMT+8, 2025-1-25 11:22 , Processed in 0.061714 second(s), 18 queries , Gzip On.
