查看: 3442|回复: 2
[ADAMS专区] ADAMS RAIL道岔模拟的问题
发表于 2012-9-18 17:18 | 显示全部楼层 |阅读模式
求助:在VI-Rail(曾经为ADAMS RAIL模块,现已独立出来)下建道岔模型时遇到问题。先是实地测量得到了一些铁轨外形数据,然后通过插值得到更多的轨外形。只是我取了不同的间距,比如在岔尖之前是每隔30mm一个RAIL PROFILE, 岔尖之后密集一些,然后一定距离之后又再稀疏一些。当进行DYANMIC ANALYSIS时,在文件成功读取后,突然跳出错误提示:error: ID: 2317 Stopping Simulating, 然后还有一个警告:The request file contains no time-dependent data。 .log文件和 .msg文件已附上,有没有童鞋知道是怎么回事啊?各位高手帮忙看看啊~~ 先谢谢大家
 楼主| 发表于 2012-9-18 17:24 | 显示全部楼层
不好意思,上传附件失败,再试一下
 楼主| 发表于 2012-9-18 17:48 | 显示全部楼层
附件中内容直接贴上,麻烦各位高手指导指导~
.msg file
INVIEW:MESSAGE91
   Adams/Solver dataset Title:
   Adams/Rail Assembly (MD Adams 2010)
INVIEW:READ_MDL
   Reading of model complete.
INBASE:DATABASE
   Input Phase - Populating Solver database
INBASE:INP_DONE
   Input Phase Complete.
ALVFIL:CPUTIME
   CPU time is 9.36006E-02 seconds.
Reading configuration file 'C:\Program Files\MSC.Software\MD_Adams_x64\2010\arail/arail.cfg'
Reading configuration file 'H:\/.acar.cfg'
  GFORCE/9
     Side: RIGHT
     WPF:  mdids://arail_shared/wheels.tbl/mdi_s1002.wpf
     CCF:  mdids://arail_shared/contact_configurations.tbl/mdi_contact_gen.ccf
  GFORCE/10
     Side: LEFT
  GFORCE/11
     Side: RIGHT
  GFORCE/12
     Side: LEFT
  GFORCE/13
     Side: RIGHT
  GFORCE/14
     Side: LEFT
  GFORCE/15
     Side: RIGHT
  GFORCE/16
     Side: LEFT
  CURVE/1
     TRK:  mdids://private/tracks.tbl/straight_switch_righthand_a15_900_000.trk
VERINP:END_INPUT
   Input and Input Check Phase complete.
GTMODE:NUMB_DOFS
   The system has 46 kinematic degrees of freedom.
GLGETL:USER_CMND
   preferences/solver=F77
GLGETL:USER_CMND
   output/nosep
GLGETL:USER_CMND
   simulate/static
SIMUL:STAT_STRT
   Entering the static equilibrium analysis phase...
ICCALC:DISPL
   Displacement initial condition analysis...
CODGEN:JAC_STAT
   Jacobian Matrix Statistics for the Initial Conditions
   Number of equations ............. = 278
   Number of non-zero entries ...... = 1632
   Percentage of matrix non-zero ... = 2.1117
   Total space used in MD array .... = 389082
SIMUL:STAT_CODE
   Performing Static analysis...
SYMBLU:STAT_QASI
   Generating the Jacobian matrix for the statics or quasi-statics problem.
CODGEN:JAC_STAT
   Jacobian Matrix Statistics for Statics
   Number of equations ............. = 955
   Number of non-zero entries ...... = 12070
   Percentage of matrix non-zero ... = 1.3234
   Total space used in MD array .... = 584706
STATIC:EQU_FND
   Static equilibrium was found after 3 iterations.
   The maximum error is 5.38014E-09 with a maximum imbalance of 1.65093E-14.
ALVSIM:STATUS
   Simulate status=0
GLGETL:USER_CMND
   array/3, numbers = 2, 1, 40.000000
GLGETL:USER_CMND
   simulate/static
SIMUL:STAT_STRT
  GFORCE/9
     Side: RIGHT
     Contact Preload: 57964.908555
   GFORCE/9
   Internal Error.
ERRMES:USER1
---- ERROR ----
   Stopping simulation
TERM:STATUS
   Termination status=-995
TERM0:EXE_TERM
      Adams/Solver execution terminated by subprogram ERRMES
TERM0:CP_TIME
   CPU time used = 0.81121 seconds
.log file
interface dialog undisplay dialog=.gui.msg_box
interface help file="forums.mscsoftware.com/adams/ubbthreads.php"
interface dialog display dialog=.RAIL.dboxes.dbox_ana_dyn_sub
interface dialog execute dialog=.RAIL.dboxes.dbox_ana_dyn_sub undisplay=no
variable set variable_name=.RAIL.dboxes.dbox_ana_dyn_sub.errorFlag int=0
if condition=(".ERRI_Wagon" == "noneActive")
   acar toolkit warning &
    warning="A full-vehicle analysis cannot be performed without a vehicle assembly."
   return
rail analysis multiple dynamics submit  &
assembly = .ERRI_Wagon  &
end_time = 2.5  &
nsteps_dtout = nsteps  &
nsteps = 3000  &
analysis_name = "test_mat_0913"  &
analysis_mode = interactive &
track = "mdids://private/tracks.tbl/straight_switch_righthand_a15_900_000.trk"  &
track_type = rigid  &
bfc_flexref_config_file = "mdids://arail_shared/guiding_rails.tbl/mdi_guiding_rail.grp"  &
ccf = "mdids://arail_shared/contact_configurations.tbl/mdi_contact_gen.ccf"  &
n_ana = 1 &
min_vx = 40 &
request_activity = no &
bfc_contact_activity = on &
wheel_flat_activity = off &
contact_graphic_activity = off &
cruise_control = off &
log_file = yes &
error_variable = .RAIL.dboxes.dbox_ana_dyn_sub.errorFLag
! Reading in property files...
!  ERRI_Front_Bogie.uer_front_PS : mdids://arail_shared/suspension_elements.tbl/mdi_PS001.sel
!  ERRI_Front_Bogie.uel_front_PS : mdids://arail_shared/suspension_elements.tbl/mdi_PS001.sel
!  ERRI_Front_Bogie.uer_rear_PS : mdids://arail_shared/suspension_elements.tbl/mdi_PS001.sel
!  ERRI_Front_Bogie.uel_rear_PS : mdids://arail_shared/suspension_elements.tbl/mdi_PS001.sel
!  ERRI_Front_Bogie.uer_SS : mdids://arail_shared/suspension_elements.tbl/mdi_SS001.sel
!  ERRI_Front_Bogie.uel_SS : mdids://arail_shared/suspension_elements.tbl/mdi_SS001.sel
!  ERRI_Front_Bogie.uer_PVD_rear : mdids://arail_shared/dampers.tbl/mdi_PVD001.dpr
!  ERRI_Front_Bogie.uel_PVD_rear : mdids://arail_shared/dampers.tbl/mdi_PVD001.dpr
!  ERRI_Front_Bogie.uer_PVD_front : mdids://arail_shared/dampers.tbl/mdi_PVD001.dpr
!  ERRI_Front_Bogie.uel_PVD_front : mdids://arail_shared/dampers.tbl/mdi_PVD001.dpr
!  ERRI_Front_Bogie.uer_SLD : mdids://arail_shared/dampers.tbl/mdi_SLD001.dpr
!  ERRI_Front_Bogie.uel_SLD : mdids://arail_shared/dampers.tbl/mdi_SLD001.dpr
!  ERRI_Front_Bogie.uer_SVD : mdids://arail_shared/dampers.tbl/mdi_SVD001.dpr
!  ERRI_Front_Bogie.uel_SVD : mdids://arail_shared/dampers.tbl/mdi_SVD001.dpr
!  ERRI_Front_Bogie.uer_SYD : mdids://arail_shared/dampers.tbl/mdi_SYD001.dpr
!  ERRI_Front_Bogie.uel_SYD : mdids://arail_shared/dampers.tbl/mdi_SYD001.dpr
!  ERRI_Front_Bogie.bgr_rear_trail_bush : mdids://arail_shared/bushings.tbl/erri_trail_arm.bus
!  ERRI_Front_Bogie.bgl_rear_trail_bush : mdids://arail_shared/bushings.tbl/erri_trail_arm.bus
!  ERRI_Front_Bogie.bgr_front_trail_bush : mdids://arail_shared/bushings.tbl/erri_trail_arm.bus
!  ERRI_Front_Bogie.bgl_front_trail_bush : mdids://arail_shared/bushings.tbl/erri_trail_arm.bus
!  ERRI_Front_Bogie.bur_BStop : mdids://arail_shared/bumpstops.tbl/mdi_BS001.bum
!  ERRI_Front_Bogie.bul_BStop : mdids://arail_shared/bumpstops.tbl/mdi_BS001.bum
!  ERRI_Rear_Bogie.uer_front_PS : mdids://arail_shared/suspension_elements.tbl/mdi_PS001.sel
!  ERRI_Rear_Bogie.uel_front_PS : mdids://arail_shared/suspension_elements.tbl/mdi_PS001.sel
!  ERRI_Rear_Bogie.uer_rear_PS : mdids://arail_shared/suspension_elements.tbl/mdi_PS001.sel
!  ERRI_Rear_Bogie.uel_rear_PS : mdids://arail_shared/suspension_elements.tbl/mdi_PS001.sel
!  ERRI_Rear_Bogie.uer_SS : mdids://arail_shared/suspension_elements.tbl/mdi_SS001.sel
!  ERRI_Rear_Bogie.uel_SS : mdids://arail_shared/suspension_elements.tbl/mdi_SS001.sel
!  ERRI_Rear_Bogie.uer_PVD_rear : mdids://arail_shared/dampers.tbl/mdi_PVD001.dpr
!  ERRI_Rear_Bogie.uel_PVD_rear : mdids://arail_shared/dampers.tbl/mdi_PVD001.dpr
!  ERRI_Rear_Bogie.uer_PVD_front : mdids://arail_shared/dampers.tbl/mdi_PVD001.dpr
!  ERRI_Rear_Bogie.uel_PVD_front : mdids://arail_shared/dampers.tbl/mdi_PVD001.dpr
!  ERRI_Rear_Bogie.uer_SLD : mdids://arail_shared/dampers.tbl/mdi_SLD001.dpr
!  ERRI_Rear_Bogie.uel_SLD : mdids://arail_shared/dampers.tbl/mdi_SLD001.dpr
!  ERRI_Rear_Bogie.uer_SVD : mdids://arail_shared/dampers.tbl/mdi_SVD001.dpr
!  ERRI_Rear_Bogie.uel_SVD : mdids://arail_shared/dampers.tbl/mdi_SVD001.dpr
!  ERRI_Rear_Bogie.uer_SYD : mdids://arail_shared/dampers.tbl/mdi_SYD001.dpr
!  ERRI_Rear_Bogie.uel_SYD : mdids://arail_shared/dampers.tbl/mdi_SYD001.dpr
!  ERRI_Rear_Bogie.bgr_rear_trail_bush : mdids://arail_shared/bushings.tbl/erri_trail_arm.bus
!  ERRI_Rear_Bogie.bgl_rear_trail_bush : mdids://arail_shared/bushings.tbl/erri_trail_arm.bus
!  ERRI_Rear_Bogie.bgr_front_trail_bush : mdids://arail_shared/bushings.tbl/erri_trail_arm.bus
!  ERRI_Rear_Bogie.bgl_front_trail_bush : mdids://arail_shared/bushings.tbl/erri_trail_arm.bus
!  ERRI_Rear_Bogie.bur_BStop : mdids://arail_shared/bumpstops.tbl/mdi_BS001.bum
!  ERRI_Rear_Bogie.bul_BStop : mdids://arail_shared/bumpstops.tbl/mdi_BS001.bum
! Reading of property files completed.
! ERROR:  ---------------------------------------------------------------------
! ERROR:  Error detected on line number 850, character 153 of the macro '.RAIL.macros.mac_ana_set'.
! ERROR:  There is more than one database object named "ERRI_Front_Bogie_ues_erri_wst_1_track"
! ERROR:  The command was not executed.
! ERROR:  +4&>           track=(eval( .RAIL.macros.mac_ana_set.loopObj.object_value.parent.name//"_"//.RAIL.macros.mac_ana_set.
! loopObj.object_value.name//"_1_track" )) &
! ERROR:  Error detected on line number 934, character 153 of the macro '.RAIL.macros.mac_ana_set'.
! ERROR:  There is more than one database object named "ERRI_Front_Bogie_ues_erri_wst_2_track"
! loopObj.object_value.name//"_2_track" )) &
! ERROR:  There is more than one database object named "ERRI_Rear_Bogie_ues_erri_wst_1_track"
! ERROR:  There is more than one database object named "ERRI_Rear_Bogie_ues_erri_wst_2_track"
! Writing assembly information to ADAMS/Solver dataset...
! Starting dynamic analysis #1 of vehicle assembly...
! The analysis has been submitted.
! File Name: test_mat_0913_dyn.res   Time Steps: 1  Start Time: 0.0   Stop Time: 0.0  (sec)
! ERROR:  Error detected on line number 60, character 119 of the macro '.ACAR.macros.mac_pos_ana_res_rea'.
! ERROR:  "refresh_stripcharts" is not a known constant, function or variable
! ERROR:    (eval(<<refresh_stripcharts>>(.ERRI_Wagon,stoo(".ERRI_Wagon."//.ACAR.macros.mac_pos_ana_res_rea.resname[1]))))
! ERROR:  +11&>              (eval(refresh_stripcharts(.ERRI_Wagon,stoo(".ERRI_Wagon."//.ACAR.macros.mac_pos_ana_res_rea.resname[1]))
! WARNING:  The request file contains no time-dependent data.
! File Name: test_mat_0913_dyn.req   Time Steps: 0  Start Time: 0.0   Stop Time: 0.0  (sec)
! File Name: test_mat_0913_dyn.gra   Time Steps: 1  Start Time: 0.0   Stop Time: 0.0  (sec)
! ERROR:  Simulation failed (Program Error) !
! ERROR:
! ERROR:  Please review the message file 'test_mat_0913_dyn.msg' for details.
if condition=(!.RAIL.dboxes.dbox_ana_dyn_sub.errorFlag)
   interface dialog undisplay dialog=.RAIL.dboxes.dbox_ana_dyn_sub
GMT+8, 2025-1-28 19:15 , Processed in 0.068123 second(s), 18 queries , Gzip On.
