查看: 1566|回复: 1
[其他相关] 斜率(位移梯度)描述无限小转动或有限转动时线性化问题
发表于 2012-9-16 22:16 | 显示全部楼层 |阅读模式
用斜率(位移梯度)去描述无限小转动或有限转动,怎么就会使斜率(位移梯度)线性化了?
我在一篇文章中看到这样一段:In the finite element literature, beams and plates are not treated as isoparametric elements because the displacement gradients at the nodes are used to describe infinitesimal rotations. Such a linearization of the slopes leads to incorrect rigid body equations of motion when the beams and plates rotate as rigid bodies.
中文意思包含了,我前面第一段中文部分,不是很理解,请教各位大侠。
 楼主| 发表于 2012-9-20 21:49 | 显示全部楼层
这几天通过看书,我理解下来应该是这个意思:斜率应该等于无限小转动的正切,因为是无限小转动,为了计算方便,认为斜率就等于无限小转动,从而线性化了斜率。
GMT+8, 2024-11-29 09:46 , Processed in 0.059079 second(s), 17 queries , Gzip On.
