查看: 3284|回复: 4
[ADAMS专区] adams构件问题,请各位帮帮忙啊
发表于 2012-9-7 16:34 | 显示全部楼层 |阅读模式
各位大虾:
       本人菜鸟,请问adams中构件最多不能超过25个吗?超过了怎么办啊
发表于 2012-9-7 18:07 | 显示全部楼层
没听说过这样的限制,见过600多个零件的,关键是你的机器能不能跑动
 楼主| 发表于 2012-9-9 17:13 | 显示全部楼层
机器不能动啊。ADAMS中进行静平衡计算时出现的错误,
     ERROR:
Static equilibrium analysis has not been successful.
  The maximum number of iterations 25, has been reached.
  For the last attempted iteration:
  The equation with the largest error was asm0005_1.PART2 Comp = 2 Error = 192.722545
  The variable receiving the largest increment was asm0005_1.PART26 Comp = 5 Delta = 24516624999.999996.
ERROR:   Simulation failure detected.
发表于 2012-11-19 10:11 | 显示全部楼层
没这种限制吧。。。
发表于 2013-7-10 21:25 | 显示全部楼层
这个25应该不是构件数
GMT+8, 2024-12-28 15:04 , Processed in 0.094417 second(s), 18 queries , Gzip On.
