查看: 5313|回复: 3
[CFX应用] CFX非定常计算,出现错误,各位朋友帮一下!
发表于 2012-9-6 11:08 | 显示全部楼层 |阅读模式
如题,出现如下错误:
之前把内存分配系数我也改为1.3了,步长也改小了好多,还是不行,就是不知道拿出错了。网格质量也检查了,还不错。
我用的计算机是4核8线程的,提交计算任务的时候尝试过用6核计算和用8核计算,都算不下去,并出现以下错误,不知道哪出错了。
COEFFICIENT LOOP ITERATION =    5              CPU SECONDS = 4.989E+04
|       Equation       | Rate | RMS Res | Max Res |  Linear Solution |
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| Message:                                                           |
| Floating point exception: Overflow                                 |
| Message:                                                           |
| Stopped in routine FPX: C_FPX_HANDLER                              |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
 楼主| 发表于 2012-9-6 11:08 | 显示全部楼层
自己先顶一下
发表于 2017-8-4 10:20 | 显示全部楼层
你好,我也遇到了相同问题,想问下如何解决啊
发表于 2017-8-4 10:23 | 显示全部楼层
你好,你的解决了吗?
GMT+8, 2025-3-13 11:29 , Processed in 0.074488 second(s), 19 queries , Gzip On.
