查看: 2169|回复: 2
[综合讨论] Nastran计算声模态时遇到的一个错误,跪求解答
发表于 2012-8-2 22:20 | 显示全部楼层 |阅读模式
用nastran进行声腔模态计算
出现以下错误提示,请教高手
*** USER FATAL MESSAGE 2049 (GP4)
     UNDEFINED GRID POINT          1 HAS A COORDINATE REFERENCED ON A CONSTRAINT CARD.
bdf文件如下
$ NASTRAN input file created by the Patran 2008r1 (MD Enabled) input
$ file translator on August    02, 2012 at 22:09:59.
$ Direct Text Input for Nastran System Cell Section
$ Direct Text Input for File Management Section
$ Normal Modes Analysis, Database
SOL 103
$ Direct Text Input for Executive Control
CEND
TITLE = MD Nastran job created on 02-Aug-12 at 21:59:02
ECHO = NONE
RESVEC = YES
$ Direct Text Input for Global Case Control Data
SUBCASE 1
   TITLE=This is a default subcase.
   METHOD = 1
   SPC = 2
   VECTOR(SORT1,REAL)=ALL
   SPCFORCES(SORT1,REAL)=ALL
$ Direct Text Input for this Subcase
BEGIN BULK
PARAM    POST    -1
PARAM   PRTMAXIM YES
EIGRL    1                       40      0                       MASS
$ Direct Text Input for Bulk Data
$ Elements and Element Properties for region : p1
PSOLID   1       1       0                               PFLUID
$ Pset: "p1" will be imported as: "psolid.1"
CHEXA    1       1       1       2       23      22      442     443
         464     463.......
$ Loads for Load Case : Default
SPCADD   2       1
$ Displacement Constraints of Load Set : b1
SPC1     1       123456  1       THRU    463
SPC1     1       123456  483     484     504     505     525     526.......
$ Referenced Coordinate Frames
ENDDATA dedc9171
还请高手们帮忙看看,指点一下,感激不尽
发表于 2012-8-2 23:09 | 显示全部楼层
为什么不用VL算呢?一分钟的事情。用Nastran做声学的人是很少的。
发表于 2012-9-10 19:53 | 显示全部楼层
正打算学nastran呢
GMT+8, 2025-1-27 21:12 , Processed in 0.091073 second(s), 19 queries , Gzip On.
