查看: 5675|回复: 1
[Workbench] 静态分析求解时出现两处错误?请各位高手帮忙看看!
发表于 2012-7-6 17:18 | 显示全部楼层 |阅读模式
(1)Error: An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports.  Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present.  Please see the Troubleshooting section of the Help System for more information.
(2)Warning: Solver pivot warnings have been encountered during the solution.  This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues.  Check results carefully.        Project>Model>Static Structural>Solution        7/6/2012 5:07:54 PM
发表于 2012-7-7 08:22 | 显示全部楼层
检查各接触面边界条件,确认没有多余的free自由度
GMT+8, 2025-1-10 20:41 , Processed in 0.066924 second(s), 17 queries , Gzip On.
