查看: 13654|回复: 2
[Workbench] 求解静态分析时,不知各位有没有出现过相类似的问题?
发表于 2012-7-6 11:27 | 显示全部楼层 |阅读模式
Warning: One or more contact regions may not be in initial contact.  Check results carefully.  Refer to Troubleshooting in the Help System for more details.        Project>Model>Static Structural>Solution        7/6/2012 11:17:38 AM
Warning: One or more MPC contact regions or remote boundary conditions may have conflicts with other applied boundary conditions or other contact regions.  Refer to Troubleshooting in the Help System for more details.        Project>Model>Static Structural>Solution        7/6/2012 11:17:38 AM
Warning: Solver pivot warnings have been encountered during the solution.  This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues.  Check results carefully.
Error: An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports.  Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present.  Please see the Troubleshooting section of the Help System for more information.        Project>Model>Static Structural>Solution        7/6/2012 11:17:38 AM
发表于 2012-7-6 12:00 | 显示全部楼层
接触面边界条件相互矛盾,请手动检查并设置各接触面的约束条件
 楼主| 发表于 2012-7-6 15:48 | 显示全部楼层
我查看了solution information 里的内容,里面指出哪里出了问题,都是以单元或节点的编号指出,可是好像在workbench中没有工具让单元或节点显示其编号。
GMT+8, 2025-1-10 20:46 , Processed in 0.052949 second(s), 17 queries , Gzip On.
