查看: 3657|回复: 5
[Nastran专区] 请教如何用matlab读取从nastran导出的刚度质量阵pch文件?
发表于 2012-6-27 10:09 | 显示全部楼层 |阅读模式
通过命令
SOL 103
$ Direct Text Input for Executive Control
DIAG 8
COMPILE SEMG $
ALTER 'KJJZ.*STIFFNESS' $
ALTER 'MJJX,.*MASS' $
MATPCH KJJZ,MJJX, , // $$
CEND
导出了刚度阵、质量阵pch文件(附件),请问有什么方法用matlab读取成矩阵形式?
多谢
bbb.rar
165.11 KB, 下载次数: 18
发表于 2012-7-10 03:48 | 显示全部楼层
%this program is to read the mass matrix and the stiffness matrix
%KAAX the stiffness matrix
%MAAS the mass matrix
% DMIG    KAAX           0       6       2       0      273(dof)
% DMIG*   KAAX                           1(node)               1(x)
% *                      1(node)               1(x) 5.087395182D+07
% DMIG*   KAAX                           1               2
% *                      1               1 1.999892380D+07
% *                      1               2 5.087395182D+07
% DMIG*   KAAX                           1               6
% *                      1               1-5.470769237D+01
% *                      1               2 5.470769237D+01
% *                      1               6 2.779150772D+00
% DMIG*   KAAX                           2               1
% *                      1               1-2.933333642D+07
% *                      1               2 1.537383915D+06
% *                      2               1 1.017479036D+08
% there are 91 node and each node has 3 freedome, so the matrix is a square
% demension 273 matrix
clc
clear all
pretitle='plate_quad';
Nnode=2;
Nfreq=101;
titleB=(['D:\chongxinyuan\Dropbox\matlab\FEM_BEM\',pretitle,'.pch']);
% titleB=(['F:\patranData\',pretitle,'.pch']);
% titleB=(['D:\chongxinyuan\',pretitle,'.f06']);
fid = fopen(titleB, 'r');
dof=273;
Kaax=zeros(dof);
Maax=zeros(dof);
h=1;
column=0;
while ~feof(fid)
    tline=fgetl(fid);
    if (length(tline)==56) && strcmp(tline(9:12),'KAAX')==1
        column=column+1;
    elseif length(tline)==56 && (str2num(tline(40))==1 || str2num(tline(40))==2)
        lin=(str2num(tline(23:24))-1)*3+ str2num(tline(40));
        Kaax(lin,column) =str2num(tline(41:55));
    elseif length(tline)==56 && str2num(tline(40))==6
        lin=(str2num(tline(23:24))-1)*3+ 3;
    elseif (length(tline)==56) && strcmp(tline(9:12),'MAAX')==1 % don't mix the mass matrix
        break
    fclose(fid);
    massok=0;
    column2=0;
fid1 = fopen(titleB, 'r');
    while ~feof(fid1)
    tline=fgetl(fid1);
    if length(tline)==72
        massok=massok+1; % determine where is the mass matrix
    elseif (length(tline)==56) && strcmp(tline(9:12),'MAAX')==1 && massok==2
        column2=column2+1;
    elseif length(tline)==56 && (str2num(tline(40))==1 || str2num(tline(40))==2) && massok==2
        Maax(lin,column2) =str2num(tline(41:55));
    elseif length(tline)==56 && str2num(tline(40))==6 && massok==2
    fclose(fid1);
发表于 2012-7-10 03:49 | 显示全部楼层
今天刚刚写的,试过可以用。注意修改下dof
发表于 2012-7-10 03:53 | 显示全部楼层
对了,因为里面是双数度D,如 1.999892380D+07,要用替换,替换成E,不然读取有错误。
 楼主| 发表于 2012-7-10 08:49 | 显示全部楼层
回复 5 # yuanchongxin 的帖子
太感谢了,真是解决了燃眉之急啊,多谢!
发表于 2015-5-7 17:57 | 显示全部楼层
为甚么我用上面的代码输入,Nastran闪退,pch文件无法生成?
GMT+8, 2024-12-28 13:48 , Processed in 0.111242 second(s), 22 queries , Gzip On.
