查看: 4974|回复: 7
[ADAMS专区] adams仿真构件横向飞出
发表于 2012-6-21 21:46 | 显示全部楼层 |阅读模式
仿真求解时,构件横向飞出,在verify model里有如下提示:
67 Gruebler Count (approximate degrees of freedom)
  68 Moving Parts (not including ground)
  68 Revolute Joints
   1 Motions
  70 Degrees of Freedom for .zhichi1
There are 3 redundant constraint equations.
   This constraint:                      unnecessarily removes this DOF:
   .zhichi1.JOINT_4   (Revolute Joint)   Rotation Between Zi & Xj
   .zhichi1.JOINT_39  (Revolute Joint)   Rotation Between Zi & Yj
   .zhichi1.JOINT_45  (Revolute Joint)   Rotation Between Zi & Xj
所有旋转副转轴都平行于Z轴,且构件也是沿Z轴飞出,我的重力方向也是正确的,为-Y向。
Rotation Between Zi & Xj是什么意思,如何去除这三个过约束?
谢谢大家!
 楼主| 发表于 2012-6-25 08:18 | 显示全部楼层
构件间的碰撞我选的是solid to solid,材料为钢,碰撞系统等,都是默认的。
 楼主| 发表于 2012-6-30 10:44 | 显示全部楼层
住址模型如下图:
所有链节间加的是旋转辐,链轮和地面问加的也是旋转辐。
求解错误提示:
ERROR:   At time  1.758085069E+00 the integrator is unable to start/restart.  Possible Causes:
(1) The accuracy required for the numerical solution can not be attained.
Relax (increase) the value of the acceptable integration ERROR.
(2) Incompatible redundant constraints, a lock up, or a bifurcation situation.  The latter two indicate a mechanism design problem.
(3) The system includes a zero (or relatively small) mass on a part with an unconstrained translational degree of freedom.
Make sure you have mass on all parts with translational degrees of freedom.
(4) The system includes a zero (or relatively small) inertia on a part with an unconstrained rotational degree of freedom.Make sure you have inertias on all parts with rotational degrees of freedom.
(5) An Adams element has a function expression that equals exactly itself.
For example,
     SFORCE/id1,I=id2,J=id3,ROT,FUNC=SFORCE(id1,jflag,comp,rm),and
     DIFF/id4,IMPLICIT,IC=0,FUNC=DIF1(id4).
Similarly,
     VARIABLE/id5, FUNC=VARVAL(id5)*TIME
equals itself at 1 second. Avoid setting an Adams element equal to itself.
ERROR:   Simulation failure detected.
我检查了,质量和惯量都是对的,没检查出哪个质量有问题
 楼主| 发表于 2012-6-30 10:47 | 显示全部楼层
在 adams里如何查每个构件的自由度,如我想知道part2被约束了几个自由度,分别是哪个自由度?
 楼主| 发表于 2012-7-3 21:25 | 显示全部楼层
求高人指点啊!
发表于 2012-11-19 10:09 | 显示全部楼层
不懂。。。
发表于 2014-5-21 16:55 | 显示全部楼层
这个应该表示你的模型自由度是70,正常加上motion后的自由度是0.
这样能进行运动学仿真了,就是能动起来。
存在过约束也能进行仿真,所以问题的主要部分还是自由度哪那里
发表于 2014-6-16 20:35 | 显示全部楼层
好东东,谢谢楼主
http://ppspptv.org/   http://wendatong.org/   http://3gxh.net/sitemap.html
GMT+8, 2024-12-28 11:29 , Processed in 0.101497 second(s), 23 queries , Gzip On.
