查看: 1666|回复: 5
[编程技巧] 怎样用matlab编程统计txt文件中有多少个数
发表于 2012-6-7 18:06 | 显示全部楼层 |阅读模式
发表于 2012-6-8 01:21 | 显示全部楼层
help fscanf
help length
 楼主| 发表于 2012-6-10 20:10 | 显示全部楼层
回复 2 # ChaChing 的帖子
可以说下具体的程序语句吗
 楼主| 发表于 2012-6-10 20:11 | 显示全部楼层
回复 2 # ChaChing 的帖子
我是新手,毕业设计卡在这里了
反对: 5.0
反对: 5
请善用编辑功能!  发表于 2012-6-10 22:30
发表于 2012-6-10 22:38 | 显示全部楼层
LZ有看了help!?
[A,count] = fscanf(fid, format, size) reads the amount of data specified by size, converts it according to the specified format string, and returns it along with a count of values successfully read. size is an argument that determines how much data is read. Valid options are
n          Read at most n numbers, characters, or strings.
inf        Read to the end of the file.
[m,n]   Read at most (m*n) numbers, characters, or strings. Fill a matrix of at most m rows in column order. n can be inf, but m cannot.
  1. fid=fopen('2.txt'); aa=fscanf(fid,'%g', [1 inf]); aa_size=length(aa)
 楼主| 发表于 2012-6-11 15:15 | 显示全部楼层
回复 5 # ChaChing 的帖子
谢谢,解决了
GMT+8, 2025-1-8 03:03 , Processed in 0.057986 second(s), 18 queries , Gzip On.
