查看: 2443|回复: 1
[前后处理] One or more elements have become highly distorted
发表于 2012-6-3 18:43 | 显示全部楼层 |阅读模式
One or more elements have become highly distorted.  Excessive
distortion of elements is usually a symptom indicating the need for
corrective action elsewhere.  Try incrementing the load more slowly
(increase the number of substeps or decrease the time step size).  You
may need to improve your mesh to obtain elements with better aspect
ratios.  Also consider the behavior of materials, contact pairs,
and/or constraint equations.  If this message appears in the first
iteration of first substep, be sure to perform element shape checking.
这个问题怎么解决啊?谢谢大家
发表于 2012-6-4 10:05 | 显示全部楼层
你看看你的材料参数和载荷参数有没有不合理的,或是细化一下网格
GMT+8, 2025-1-10 20:48 , Processed in 0.098908 second(s), 17 queries , Gzip On.
