楼主: superxjw
[Virtual.Lab] LMS Virtual.Lab进排气消声器资料
发表于 2012-7-15 16:30 | 显示全部楼层
这是我的cdb文件部分内容,请问有什么问题呢,就是没显示
/COM,ANSYS RELEASE 12.0.1  UP20090415       16:29:36    07/12/2012
/PREP7
/NOPR
/TITLE,zhangguoqing1986
*IF,_CDRDOFF,EQ,1,THEN     !if solid model was read in
_CDRDOFF=             !reset flag, numoffs already performed
*ELSE              !offset database for the following FE model
NUMOFF,NODE,   10480
NUMOFF,ELEM,    3507
NUMOFF,MAT ,       1
NUMOFF,REAL,       1
NUMOFF,TYPE,       1
*ENDIF
*SET,_BUTTON ,  1.000000000000
*SET,_CHKMSH , -1.000000000000
*SET,_ET_NEXT,  2.000000000000
*SET,_ET_TYPE,  1.000000000000
*SET,_GUI_CLR_BG,' systemButtonFace               '
*SET,_GUI_CLR_FG,' systemButtonText               '
*SET,_GUI_CLR_INFOBG,' systemInfoBackground           '
*SET,_GUI_CLR_SEL,' systemHighlight                '
*SET,_GUI_CLR_SELBG,' systemHighlight                '
*SET,_GUI_CLR_SELFG,' systemHighlightText            '
*SET,_GUI_CLR_WIN,' systemWindow                   '
*SET,_GUI_FNT_FMLY,'䭊伓                          '
*SET,_GUI_FNT_PXLS,  16.00000000000
*SET,_GUI_FNT_SLNT,'r                               '
*SET,_GUI_FNT_WEGT,'medium                          '
*SET,_RC_SET ,  1.000000000000
*SET,_RETURN ,  0.000000000000
*SET,_STATUS ,  1.000000000000
*SET,_UIQR   ,  1.000000000000
DOF,DELETE
ET,       1,150
RLBLOCK,       1,       1,       6,       7
(2i8,6g16.9)
(7g16.9)
       1       6 0.250000000E-02  0.00000000      0.00000000      0.00000000      0.00000000      0.00000000
NBLOCK,6,SOLID,     10480,     10209
(3i8,6e20.13)
       1      21       0-5.5827897353940E+01
       2      11       0 5.5827897353940E+01
       3      22    2273-5.5685620144109E+01 0.0000000000000E+00 3.9831937095787E+00
       4      22    4545-5.5259763306937E+01 0.0000000000000E+00 7.9443490748706E+00
       5      22    6818-5.4552122716804E+01 0.0000000000000E+00 1.1866761565516E+01
       6      22    9091-5.3566430318872E+01 0.0000000000000E+00 1.5728689260569E+01
       7      22   11364-5.2307710191081E+01 0.0000000000000E+00 1.9510447906902E+01
       8      22   13636-5.0783106607106E+01
发表于 2012-7-15 17:26 | 显示全部楼层
我的cdb文件有什么问题呢
/PREP7
/NOPR
NUMOFF,NODE,   10480
NUMOFF,ELEM,    3507
NUMOFF,MAT ,       1
NUMOFF,REAL,       1
NUMOFF,TYPE,       1
*ENDIF
 楼主| 发表于 2012-7-15 17:30 | 显示全部楼层
回复 15 # kiss5798539 的帖子
ANSYS不能输出BDF格式。8B太老了!估计ANSYS 12写出的网格8B读不了。我都给你说了办法了啊,你SYSNOISE能读么,你读入SYSNOISE后从SYSNOISE输出Nastran的bdf格式,这样VL应该就能读了。或者还有个办法,你换个新版本的VL吧。现在最新的是10,VL11也快出来了。
发表于 2012-7-15 22:00 | 显示全部楼层
好的谢谢
发表于 2012-8-1 10:16 | 显示全部楼层
这个真心不错啊,谢谢
发表于 2012-8-23 09:44 | 显示全部楼层
谢谢了,我才入门,这些资料很有帮助
发表于 2012-8-23 19:05 | 显示全部楼层
哈哈哈哈哈哈哈
发表于 2012-8-23 19:06 | 显示全部楼层
哈哈哈哈哈
海带海带还会待会带坏
发表于 2012-8-23 19:07 | 显示全部楼层
加多少了分就算了看法就是浪费
发表于 2012-8-23 19:08 | 显示全部楼层
哈哈哈哈哈哈哈
 楼主| 发表于 2012-8-23 21:37 | 显示全部楼层
回复 23 # wangzhigangting 的帖子
灌水贴按照论坛规矩是要处罚的,下次不要这样了,去签个到积分就很多了。
发表于 2012-8-24 15:27 | 显示全部楼层
回复 27 # superxjw 的帖子
不好意思!:@(!
发表于 2012-9-6 15:08 | 显示全部楼层
谢谢分享
发表于 2012-9-7 12:54 | 显示全部楼层
没体能咯额
GMT+8, 2025-1-10 21:37 , Processed in 0.075198 second(s), 17 queries , Gzip On.
