查看: 1257|回复: 0
[图像处理] 求大神解救啊!!!
发表于 2012-5-23 13:05 | 显示全部楼层 |阅读模式
求每句语言是意思~
clear all;
close all;
Img = imread('twocells.bmp');  % The same cell image in the paper is used here
Img=double(Img(:,:,1));
sigma=1.5;    % scale parameter in Gaussian kernel for smoothing.
G=fspecial('gaussian',15,sigma);
Img_smooth=conv2(Img,G,'same');  % smooth image by Gaussiin convolution
[Ix,Iy]=gradient(Img_smooth);
f=Ix.^2+Iy.^2;
g=1./(1+f);  % edge indicator function.
epsilon=1.5; % the papramater in the definition of smoothed Dirac function
timestep=5;  % time step
mu=0.04;  % coefficient of the internal (penalizing) energy term P(\phi)
          % Note: The product timestep*mu must be less than 0.25 for stable evolution
lambda=5; % coefficient of the weighted length term Lg(\phi)
alf=1.5;   % coefficient of the weighted area term Ag(\phi);
           % Note: Choose a positive(negative) alf if the initial contour is outside(inside) the object.
% define initial level set function (LSF) as -c0, c0 at points outside and inside of a region R, respectively.
[nrow, ncol]=size(Img);
c0=2;    % The constant value used to define binary level set function as initial LSF;
         % Using larger value of c0 usually slow down the evolution.
initialLSF=c0*ones(nrow,ncol);
w=8;
initialLSF(w+1:end-w, w+1:end-w)=-c0;
u=initialLSF;
figure;imagesc(Img, [0, 255]);colormap(gray);hold on;
[c,h] = contour(u,[0 0],'r');
title('Initial contour');
% start level set evolution
for n=1:200
    u=EVOLUTION_LSD(u, g ,lambda, mu, alf, epsilon, timestep, 1);
    if mod(n,20)==0
        pause(0.001);
        iterNum=[num2str(n), ' iterations'];
        title(iterNum);
        hold off;
totalIterNum=[num2str(n), ' iterations'];
title(['Final contour, ', totalIterNum]);
figure;
mesh(u);
title('Final level set function');
GMT+8, 2025-1-8 08:06 , Processed in 0.063742 second(s), 18 queries , Gzip On.
