查看: 6936|回复: 0
[综合讨论] 毕设同样问题多次出现,求高手解答。。。
发表于 2012-5-19 22:21 | 显示全部楼层 |阅读模式
    6850 t 9.5989E+02 dt 1.32E-01 write d3plot file
dt of cycle    6900 is controlled by solid      element   11972
time...........................   9.64841E+02
time step......................   7.24739E-02
kinetic energy.................   5.27053E+00
internal energy................   1.21550E+00
spring and damper energy.......   1.00000E-20
hourglass energy ..............   8.01698E-01
system damping energy..........   0.00000E+00
sliding interface energy.......   9.63924E-01
external work..................   0.00000E+00
eroded kinetic energy..........   0.00000E+00
eroded internal energy.........   0.00000E+00
eroded hourglass energy........   0.00000E+00
total energy...................   8.25165E+00
total energy / initial energy..   3.04023E-02
energy ratio w/o eroded energy.   3.04023E-02
global x velocity..............   1.12814E-08
global y velocity..............   1.44319E-08
global z velocity..............  -9.84987E-12
cpu time per zone cycle............         0 nanoseconds
average cpu time per zone cycle....     12044 nanoseconds
average clock time per zone cycle..     12042 nanoseconds
    6975 t 9.6999E+02 dt 6.55E-02 write d3plot file
dt of cycle    7000 is controlled by solid      element    8507
time...........................   9.71163E+02
time step......................   2.91174E-02
kinetic energy.................   5.23889E+00
internal energy................   1.19847E+00
hourglass energy ..............   8.03986E-01
sliding interface energy.......   9.54896E-01
total energy...................   8.19624E+00
total energy / initial energy..   3.01982E-02
energy ratio w/o eroded energy.   3.01982E-02
global x velocity..............   1.12830E-08
global y velocity..............   1.45545E-08
global z velocity..............  -5.92363E-13
average cpu time per zone cycle....     11954 nanoseconds
average clock time per zone cycle..     11959 nanoseconds
*** Warning negative vol in advection redo cycle     7082
*** Warning negative vol in advection redo cycle     7083
node #       1 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #       2 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #       3 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #       4 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #       5 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #       6 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #       7 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #       8 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #       9 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      10 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      11 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      12 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      13 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      14 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      15 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      16 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      17 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      18 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      19 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      20 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      21 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      22 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      23 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      24 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      25 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      26 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      27 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      28 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      29 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
node #      30 has out-of-range velocities
    x-velocity= NaN
    y-velocity= NaN
    z-velocity= NaN
    7100 t 9.7229E+02 dt 0.00E+00 write d3plot file
E r r o r   t e r m i n a t i o n
s t o r a g e   a l l o c a t i o n
Memory required to complete solution   :      5593379
Additional dynamically allocated memory:       621095
                                   Total:      6214474
T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Initialization ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Element processing ... 1.1340E+03   97.34     1.1363E+03   97.54
  Binary databases ..... 6.0000E+00    0.52     3.8570E+00    0.33
  ASCII database ....... 1.1000E+01    0.94     8.2040E+00    0.70
  Contact algorithm .... 1.4000E+01    1.20     1.6574E+01    1.42
    ALE CoupleID       1 1.4000E+01    1.20     1.5853E+01    1.36
  Contact entities ..... 0.0000E+00    0.00     0.0000E+00    0.00
  Rigid bodies ......... 0.0000E+00    0.00     7.9000E-02    0.01
  Implicit Nonlinear ... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Lin. Alg. ... 0.0000E+00    0.00     0.0000E+00    0.00
  T o t a l s            1.1650E+03  100.00     1.1651E+03  100.00
Problem time       =    9.7229E+02
Problem cycle      =      7100
Total CPU time     =      1165 seconds (   0 hours 19 minutes 25 seconds)
CPU time per zone cycle  =     11878 nanoseconds
Clock time per zone cycle=     11878 nanoseconds
Number of CPU's    1
NLQ used/max      96/   96
Start time   05/17/2012 13:27:52
End time     05/17/2012 13:47:21
Elapsed time    1169 seconds(  0 hours 19 min. 29 sec.) for    7100 cycles
GMT+8, 2025-1-25 21:56 , Processed in 0.074978 second(s), 18 queries , Gzip On.
