查看: 5929|回复: 1
[结构分析] 各路大哥,用LS-dyna仿真,出现如下错误,请求帮助!!!
发表于 2012-5-1 23:27 | 显示全部楼层 |阅读模式
各路大概,用LS-dyna仿真,出现如下错误,是什么原因???请求帮助!!!
Input file: transient1.k
The native file format       : 32-bit small endian
Memory size from default     :    20000000
expanding   memory to    20000000 starting ls-dyna
********  notice  ********  notice  ********  notice  ********
* This is the LS-DYNA Finite Element code.                   *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results    *
* obtained from this system. The user must verify his own    *
* results.                                                   *
* LSTC endeavors to make the LS-DYNA code as complete,       *
* accurate and easy to use as possible.                      *
* Suggestions and comments are welcomed.  Please report any  *
* errors encountered in either the documentation or results  *
* immediately to LSTC through your site focus.               *
* Copyright (C) 1990-2010                                    *
* by Livermore Software Technology Corp. (LSTC)              *
* All rights reserved                                        *
contracting memory to           1 beginning of keyword reader
expanding   memory to       22280
expanding   memory to      459166
expanding   memory to     5422090
expanding   memory to     5452090
expanding   memory to     5528002
expanding   memory to     5557990
expanding   memory to     6660166
expanding   memory to     7762342
expanding   memory to     7783776
expanding   memory to     7838376
expanding   memory to     7868076
expanding   memory to     7888076
expanding   memory to     7968906
expanding   memory to     8039736
expanding   memory to    10296310
expanding   memory to    10369792
expanding   memory to    15291694
expanding   memory to    15362524
Memory required to process keyword     :     15362524
contracting memory to           1 end of keyword reader
LS-DYNA will perform a structural only analysis
  Model asm1012
                         ls-dyna ls971s.59419 R5.0    date 04/10/2010
expanding   memory to        4129 material, node and element data
expanding   memory to        4227 material properties
expanding   memory to     3088435 element data
expanding   memory to     3725912 gradient of damage data
expanding   memory to     7874784 user control for contact interfaces
expanding   memory to     7874792 for boundary cond. vectorization
contracting memory to     7874764 nodal data
expanding   memory to     8147982 arbitrary element numbering input
contracting memory to     7874764 thick shell int. pt. strain
expanding   memory to    12617834 process element material data
expanding   memory to    12619855 load curve data
contracting memory to    12619756 regularize time history data
contracting memory to    12619552 rigidwall definitions
expanding   memory to    12690419 velocity b.c
expanding   memory to    12773315 nodal constraint sets
expanding   memory to    14676885 contact interfaces
expanding   memory to    14819543 implicit contact 1
expanding   memory to    15915069 implicit contact 2
*** Error 2216 (STR+216)
     part # 2 is out-of-range
          2
     input phase will continue if possible
     part # 4 is out-of-range
          4
     part # 6 is out-of-range
          6
     part # 8 is out-of-range
          8
     part # 7 is out-of-range
          7
     part # 11 is out-of-range
         11
contracting memory to    14819134 contact segment data 1
contracting memory to    14817916 contact segment data 2
expanding   memory to    17226059 contact segment data 3
contracting memory to    16785510 contact definition
expanding   memory to    16998770 rigid body
          4         5
     part # 5 is out-of-range
          4         5
*** Error 2363 (STR+363)
     on rigid body merge card number 1
     part 4 is not material type 20-rigid
          7         8
          7         8
     on rigid body merge card number 2
     part 7 is not material type 20-rigid
contracting memory to    16822850 contact friction
expanding   memory to    16912109 joints
contracting memory to    16912109 accelerometers
expanding   memory to    16912209 rigid bodies for disp. termination
contracting memory to    16912209 transformation to move nodes
expanding   memory to    16912216 thermal expansion 0
expanding   memory to    16912223 flexible body 2
contracting memory to    16912223 implicit joints
expanding   memory to    16912226 minimum contact gap for auto switching
*** Error 2018 (STR+18)
     input phase completed with 14 fatal errors
     please check messag file
发表于 2014-7-25 12:12 | 显示全部楼层
我也出现类似问题,求大神解答
GMT+8, 2025-1-6 16:21 , Processed in 0.065574 second(s), 18 queries , Gzip On.
