查看: 2330|回复: 1
[综合讨论] 小弟做压气机叶轮强度校核,计算结果出现了较大的变形量,求助?
发表于 2012-4-29 16:22 | 显示全部楼层 |阅读模式
Warning: One or more bodies may be underconstrained and experiencing rigid body motion. Weak springs have been added to attain a solution.  Refer to Troubleshooting in the Help System for more details.        Project>Model>Static Structural>Solution        4/30/2012 12:31:17 PM
Warning: An iterative solver was used for this model.  However, a direct solver may enhance performance.  Consider specifying the use of a direct solver.  Refer to Troubleshooting in the Help System for more details.        Project>Model>Static Structural>Solution        4/30/2012 12:31:19 PM
Warning: The deformation is large compared to the model bounding box.  Verify boundary conditions or consider turning large deflection on.  Refer to Troubleshooting in the Help System for more details.        Project>Model>Static Structural>Solution        4/30/2012 12:31:19 PM
小弟做压气机叶轮强度校核,将fluent的压力载荷作用于叶片,还施加离心力和重力,在结果中出现了大的变形量,为200m,这肯定错了,请各位大侠分析一下原因。小弟先谢了
发表于 2012-5-26 16:52 | 显示全部楼层
单位统一了吗?单位不统一会导致这个问题
GMT+8, 2025-1-10 20:30 , Processed in 0.124763 second(s), 20 queries , Gzip On.
