查看: 5255|回复: 15
[综合讨论] 一层混凝土框架结构的模态分析探讨
发表于 2012-4-23 08:45 | 显示全部楼层 |阅读模式
本人正在模拟一层混凝土框架结构的地震响应,需要做模态分析。
      一层混凝土框架结构包括四根柱子,四根梁,一块板。
       通过创建面,延伸面创建体(柱子),通过复制体,产生四根柱子;通过创建体,建立梁,通过复制体,产生四根梁;然后vglue胶结体;通过延伸面创建体,也就是创建板,然后胶结。
       四根柱子与梁分离式划分,板整体式划分。混凝土采用solid65单元,钢筋采用link8单元。
      网格能够划分过去,但模态分析出现错误。请高手指点。
以下为划分网格
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!划分网格!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
VSEL,ALL
VSEL,U,,,1
CM,BC,VOLU   !定义组件梁柱BC,为划分梁柱做准备
VSEL,ALL       !切割板,为了便于划分板
VSEL,S,,,1
WPOFF,,,c
VSBW,ALL
WPCSYS,-1
WPROTA,,,90
WPOFF,,,h2/2-c
VSBW,ALL
WPOFF,,,c
VSBW,ALL
*DO,I,1,num_b
WPOFF,,,Inc_b
VSBW,ALL
*ENDDO
WPOFF,,,c
VSBW,ALL
WPCSYS,-1
WPROTA,,-90,
WPOFF,,,b2/2-c
VSBW,ALL
WPOFF,,,c
VSBW,ALL
*DO,I,1,num_b
WPOFF,,,Inc_b
VSBW,ALL
*ENDDO
WPOFF,,,c
VSBW,ALL
CM,ban,VOLU
CMPLOT,ban,VOLU
!划分板
VATT,1,3,1
ESIZE,,2
MSHKEY,1
VMESH,ALL
CMSEL,S,BC,VOLU   !划分梁柱子混凝土
VATT,1,,1
ESIZE,,2
VMESH,ALL
CMSEL,S,ZZJ,LINE !划分梁柱纵筋
CMSEL,A,BZJ,LINE
LATT,2,1,2
ESIZE,,2
LMESH,ALL
CMSEL,S,ZGJ,LINE !划分梁柱箍筋
CMSEL,A,BGJ,LINE
LATT,3,2,2
ESIZE,,2
LMESH,ALL
ALLSEL,ALL
NSEL,S,LOC,Z,H
D,ALL,ALL,0
FINISH
!!!!!!!!!!!!!!!!!!!!!!!!!!!模态分析!!!!!!!!!!!!!!!!!!!!!!!
/solu
ANTYPE,2
LUMPM,OFF
MODOPT,LANB,3
MXPAND,3, , ,1
SOLVE
FINI
错误信息:
*** WARNING ***                         CP =    1206.000   TIME= 00:03:32
Real constant 1 referenced by at least element types 1 and 2.
*** ERROR ***                           CP =    1210.094   TIME= 00:03:56
The computed element record length (838) does not match the actual
element record length (849) in the .ESAV file for element 21537 of
element type 65.  Please try another element option.  The error is
harmful only when running in parallel.  The error was encountered in
sfelem.F.  Please send the data leading to this operation to your
technical support provider, as this will allow ANSYS, Inc to improve
the program.
*** ERROR ***                           CP =     978.625   TIME= 23:08:06
The computed element record length (79) does not match the actual
element record length (68) in the .ESAV file for element 49683 of
element type 8.  Please try another element option.  The error is
the program.
望高手参与讨论
 楼主| 发表于 2012-4-25 11:35 | 显示全部楼层
无人回复,我自己顶下
发表于 2012-5-12 15:17 | 显示全部楼层
回复 2 # wypzf_8 的帖子
哈哈哈哈哈哈哈
哥哥我也是甚是愁苦 我做的是七层钢框架结构 结果模态分析时候 只有板有反应 但是梁和柱子都不跟着动弹 不知道是咋回事
妹的 头都大了
发表于 2012-5-12 15:30 | 显示全部楼层
回复 3 # caire 的帖子
既然能算,说明建模没有错误。板有反应,柱子不动说明柱子的刚度远远大于板的刚度,看看参数设置是否有问题。
发表于 2012-5-12 15:32 | 显示全部楼层
回复 1 # wypzf_8 的帖子
板、柱子、梁各采用什么单元?混凝土、钢筋和板、梁、柱子都有什么关系。
发表于 2012-5-12 15:37 | 显示全部楼层
回复 4 # dujunmin 的帖子
梁和柱子用的是beam188  板用的是shell36   参数设置能不能说的具体一点 好多 我也不知道哪一步会导致这种情况  弹性模量 还有 泊松比么?
发表于 2012-5-12 15:45 | 显示全部楼层
1、“混凝土采用solid65单元,钢筋采用link8单元”是什么意思?
2、模态分析需要弹性模量、泊松比、密度,就可以了,关键是不要输错;
3、“梁和柱子用的是beam188  板用的是shell36   ”应当没有问题,梁和柱子的局部坐标不要搞错,此外就是连接点应固连在一起。
发表于 2012-5-12 16:07 | 显示全部楼层
回复 7 # dujunmin 的帖子
嗯  弹性模量 我输入的是2.06e5  泊松0.3 密度是7.8e-9   恩 弹性模量和泊松 还有密度 都是在structural  linear 还有nonliear 输入的 对么
发表于 2012-5-12 16:14 | 显示全部楼层
回复 7 # dujunmin 的帖子
嗯  有一个问题我没有闹明白 就是我的工字钢梁是焊死在板的下面的 而且是满焊  但是做计算式板和这个梁只有两边是连接的 所以我采取了一种非常规手段在板地下设置了好多 小梁 就是为了叫这个板和梁 固定连接  然后我算静力的时候 已经成功了  这个板的大体变形趋势是和梁柱一起动的 但是模态的时候 就只有板自己上下震 前三十阶都没有发现梁柱的明显变化
发表于 2012-5-12 16:17 | 显示全部楼层
把图发上来看一下可以吗?板底下的小梁的刚度和真实梁相比如何,
发表于 2012-5-12 16:26 | 显示全部楼层
回复 10 # dujunmin 的帖子
和真实梁的刚度是一样的  也是beam188 还有参数也是一样的 只是 换了一种界面类型 把工字钢换成方钢 这个是一层 其余的六层和这层是一样的 @D(6RUL7{[QVE%GK59$QYKX.jpg    那五个竖着的小条条就是我加的梁
发表于 2012-5-12 16:34 | 显示全部楼层
什么材料的模量和密度这么小,用得是什么单位?可以QQ交流吗?749192897
发表于 2012-5-12 16:42 | 显示全部楼层
就是老师  我想问你哈  这张图片 红色区域的 就是我的工字钢梁  四边都有  我有没有办法 上面薄薄的板 给它固定的连接到梁上 而不是仅仅只有四个点是连着的
 楼主| 发表于 2012-5-19 23:20 | 显示全部楼层
回复 4 # dujunmin 的帖子
呵呵,我以为我的帖子沉下去呢。我做的是一层钢筋混凝土框架结构的模态分析。定义了材料的非线性后,就不能模拟下去了。模态分析属于应该自动忽略材料的非线性吧?
发表于 2012-5-21 13:35 | 显示全部楼层
是的,模态分析不支持非线性。
GMT+8, 2025-1-10 02:27 , Processed in 0.066315 second(s), 21 queries , Gzip On.
