查看: 1070|回复: 5
帮我看看这个GUI编程的问题
发表于 2006-4-20 19:11 | 显示全部楼层 |阅读模式
%main.m<BR>clf reset<BR>set(gcf,'unit','normalized','position',[0.1,0.4,0.85,0.35]);<BR>set(gcf,'defaultuicontrolunits','normalized');<BR>set(gcf,'defaultuicontrolfontsize',11);<BR>set(gcf,'defaultucontrolhorizontal','left');<BR>set(gcf,'menubar','none');<BR>str='通过多行指令绘图的交互界面';<BR>set(gcf,'name',str,'numbertitle','off');<BR>h_axes=axes('position',[0.05,0.15,0.45,0.70],'visible','off');<BR>uicontrol(gcf,'Style','text','position',[0.52,0.87,0.26,0.1],'String','绘图指令框');<BR>hedit=uicontrol(gcf,'Style','edit','position',[0.52,0.05,0.26,0.8],'Max',2);<BR>hpop=uicontrol(gcf,'style','popup','position',[0.8,0.73,0.18,0.12],'string','spring|summer|autumn|winter');<BR>hlist=uicontrol(gcf,'style','list','position',[0.8,0.23,0.18,0.37],'sring','Grid on|Box on|Hidden off|Axis off','Max',2);<BR>hpush=uicontrol(gcf,'style','push','position',[0.8,0.05,0.18,0.15],'string','Apply');<BR>set(hedit,'callback','calledit(hedit,hpop,hlist)');<BR>set(hpop,'callback','calledit(hedit,hpop,hlist)');<BR>set(hpush,'callback','calledit(hedit,hpop,hlist)');<BR>%calledit.m<BR>function calledit(hedit,hpop,hlist)<BR>ct=get(hedit,'string');<BR>vpop=get(hpop,'value');<BR>vlist=get(hlist,'value');<BR>if ~ isempty(ct)<BR>    eval(ct)<BR>    popstr={'spring','summer','autumn','winter'};<BR>    liststr={'grid on','box on','hidden off','axis off'};<BR>    invstr={'grid off','box off','hidden on','axis on'};<BR>    colormap=(eval(popstr{vpop}))<BR>    vv=zeros(1,4);vv(vlist)=1<BR>    for k=1:4<BR>        if vv(k);eval(liststr{k});else eval(invstr{k});end<BR>    end<BR>end<BR><BR>怎么老是出现?? Error: File: C:\MATLAB6p5\work\huitushuru.m Line: 20 Column: 1<BR>A function declaration cannot appear within a script M-file.<BR><BR>还有在问问。。如何能在菜单栏里弄上个动画的选项?<BR>
发表于 2006-4-20 22:35 | 显示全部楼层
Script文件里面不能定义函数,<BR>把%main.m改成function main就行<BR>原因是只有在*.m文件才能定义函数
 楼主| 发表于 2006-4-20 22:48 | 显示全部楼层
那有没有实现图象动画的控件啊?。。<BR>就是输入个3D的绘图命令后,实现旋转之类的。。
发表于 2006-4-20 22:51 | 显示全部楼层
不是很明白。<BR>如何能在菜单栏里弄上个动画的选项?<BR><BR>可以通过菜单调用一个子程序,子程序实现视角转变。<BR>
 楼主| 发表于 2006-4-21 08:54 | 显示全部楼层
<P>就是譬如我在上边的所编出来的一个GUI里输入一个绘图程序。<BR>然后在这个GUI里点击某建实现图象的旋转。。视角的转变。。<BR>你说的那个子程序要如何编写呢?</P>
发表于 2006-4-21 21:42 | 显示全部楼层
回复:(GRF-KYO)帮我看看这个GUI编程的问题
<P>用axes,视角之类的可以用view来实现</P>
GMT+8, 2025-1-19 02:57 , Processed in 0.074905 second(s), 17 queries , Gzip On.
