查看: 2657|回复: 2
[声学基础] 求助关于fluctuation strength的计算
发表于 2012-4-11 19:51 | 显示全部楼层 |阅读模式
需要计算心理声学参数fluctuation strength,不知道什么软件可以计算啊?或者哪位高手有相关的matlab程序可以分享一下的。非常感谢啊!
发表于 2014-4-1 15:52 | 显示全部楼层
同求 同求
发表于 2014-4-2 09:52 | 显示全部楼层
下面的函数是否就是你需要的?
function varargout = mirfluctuation(orig,varargin)
%   f = mirfluctuation(x) calculates the fluctuation strength, indicating the
%       rhythmic periodicities along the different channels.
%   Optional arguments:
%       mirfluctuation(...,'MinRes',mr) specifies the minimal frequency
%           resolution of the resulting spectral decomposition, in Hz.
%               Default: mr = .01 Hz
%       mirfluctuation(...,'Summary') returns the summary of the fluctuation,
%           i.e., the summation along the critical bands.
% E. Pampalk, A. Rauber, D. Merkl, "Content-based Organization and
% Visualization of Music Archives",
这是MIRtoolbox工具箱中的一个函数,该工具箱介绍如下:
% MIRtoolbox
% Version 1.3.4 (Matlab Central version) 14-December-2011
% A more detailed documentation of each function is available using the
% help command. For instance, type help miraudio.
% A complete documentation is available in the downloaded folder and online.
%                        http://www.jyu.fi/music/coe/materials/mirtoolbox
%BASIC AUDIO OPERATIONS
% miraudio         - Loads and return waveform
% mirframe         - Decomposes into successive frames
% mirsegment       - Decomposes into successive segments
% mirlength        - Temporal length
%DATA OUTPUT
% mirgetdata       - Return result as a Matlab standard structure
% mirsave          - Save audio and other temporal data into audio files
% mirexport        - Export the analytical results to a text file
% mirplay          - Plays audio and other temporal data
%ANALYTICAL OPERATORS
% mirspectrum      - FFT spectrum with many post-processing operations
% mirautocor       - Autocorrelation function
% mirfilterbank    - Decomposes into channels via a bank of filters
% mirsum           - Sums the channels of a filterbank
%DYNAMIC
% mirrms           - Root mean square energy
% mirlowenergy     - Number of frames with lower than average energy
% mirenvelope      - Amplitude envelope (global shape of the waveform)
% mironsets        - Note onset positions and characteristics
% mirattacktime    - Duration of note attacks
% mirattackslope   - Average slope of note attacks
% mireventdensity  - Average frequency of events
%RHYTHM
% mirtempo         - Tempo (in beats per minute)
% mirfluctuation   - Fluctuation strength (periodicities in each channel)
% mirbeatspectrum  - Beat spectrum, characterizing the rhythmic content
% mirpulseclarity  - Rhythmic clarity, i.e., beat strength
%TIMBRE
% mirbrightness    - Spectral brightness (high-frequency rate)
% mirrolloff       - Spectral rolloff (frequency above which is located a
%                       certain amount of energy)
% mirmfcc          - Mel-frequency cepstrum coefficients
%                       (numerical description of the spectrum envelope)
% mirinharmonicity - Inharmonicity (partials non-multiple of fundamental)
% mirroughness     - Roughness (sensory dissonance)
% mirregularity    - Spectrum irregularity (amplitude variability of
%                        successive peaks)
%PITCH
% mirpitch         - Pitch frequencies
% mircepstrum      - Cepstrum representation (showing periodicities)
% mirmidi          - Attempts a conversion of audio into MIDI
%TONALITY
% mirchromagram    - Chromagram (distribution of energy along pitches)
% mirkeystrength   - Key strengths (probability of key candidates)
% mirkey           - Best keys and modes (in the 12 tone system)
% mirkeysom        - Visualizes key strengths with self-organizing map
% mirmode          - General estimation of mode (major/minor)
% mirtonalcentroid - Tonal centroid (using circles of fifths and thirds)
% mirhcdf          - Harmonic Change Detection Function
%PREDICTIONS
% miremotion       - Emotion, represented both as classes and dimensions
%ANALYSIS
% mirmean          - Returns the mean of any feature
% mirstd           - Returns the standard deviation of any feature
% mirstat          - Returns statistics of any feature
% mirpeaks         - Peaks
% mirhisto         - Histogram
% mirentropy       - Entropy
% mirzerocross     - Sign-changes ratio
% mircentroid      - Centroid (center of gravity)
% mirspread        - Spread (non-concentration)
% mirskewness      - Skewness (lack of symmetry)
% mirkurtosis      - Kurtosis (peakiness)
% mirflatness      - Flatness
%SIMILARITY
% mirflux          - Flux, i.e., distance between successive frames
% mirsimatrix      - Similarity matrix
% mirnovelty       - Novelty score
% mirdist          - Distance between audio files
% mirquery         - Query by example
%OTHER
% mirclassify      - Classifies audio sequences
% mircluster       - Clusters segments or frames
% mirfeatures      - Compute a large range of features
% mirmap           - Performs statistical mapping
%MATLAB FUNCTIONS generalized to the MIRtoolbox data
% +                - Superposes audio files
% *                - Combines autocor, cepstrum curves
% corrcoef         - Computes correlation between curves
%PREFERENCES
% mirchunklim      - Get or set the chunk size threshold
% mirwaitbar       - Toggles on/off the display of progress bars
% mirverbose       - Toggles on/off the display of ongoing operations
% mirparallel      - Toggles on/off parallel processing
MIRtoolbox1.5.part1.rar
4 MB, 下载次数: 0
MIRtoolbox1.5.part2.rar
4 MB, 下载次数: 0
MIRtoolbox1.5.part3.rar
4 MB, 下载次数: 0
MIRtoolbox1.5.part4.rar
4 MB, 下载次数: 0
MIRtoolbox1.5.part5.rar
4 MB, 下载次数: 0
MIRtoolbox1.5.part6.rar
789.37 KB, 下载次数: 0
GMT+8, 2025-1-11 07:02 , Processed in 0.068661 second(s), 22 queries , Gzip On.
