查看: 1453|回复: 2
[声学分析] 程序无法正常运行
发表于 2012-3-19 11:05 | 显示全部楼层 |阅读模式
ANSYS11.0中可以正常运行的程序到了ANSYS14.0中,加载的载荷就变了,ANSYS11.0中管道两端面有"Y"方向位移约束,且管内流体两端面有压力约束,到了ANSYS14.0生成的模型中的载荷就只有上半个管道上有约束载荷了,但在14.0中重新建模就正常了(上下半部分都有载荷),不知道是为啥?我用GUI界面操作的,其.log文件如下,望指点:
WPSTYLE,,,,,,,,0
/PREP7
ET,1,SOLID45
ET,2,FLUID30
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.06e11
MPDATA,PRXY,1,,0.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,7850
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,2,,1030
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,SONC,2,,1460
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MU,2,,1
CYL4, , ,0.1, ,0.11,180,0.5
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
FLST,5,1,4,ORDE,1
FITEM,5,5
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,32, , , , ,1
FLST,5,1,4,ORDE,1
FITEM,5,7
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,1,4,ORDE,1
FITEM,5,8
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
FLST,5,1,4,ORDE,1
FITEM,5,6
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,1,4,ORDE,1
FITEM,5,10
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,50, , , , ,1
MSHAPE,0,3D
MSHKEY,1
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/UI,MESH,OFF
CYL4, , , , ,0.1,180,0.5
VSEL,S, , ,       2
ASLV,R
LSLA,R
TYPE,   2
MAT,       2
REAL,
ESYS,       0
SECNUM,
FLST,5,1,4,ORDE,1
FITEM,5,16
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,34, , , , ,1
FLST,5,1,4,ORDE,1
FITEM,5,18
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,17, , , , ,1
FLST,5,1,4,ORDE,1
FITEM,5,17
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,1,4,ORDE,1
FITEM,5,20
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
EXTO,VSWE,AUTO,OFF
VSWEEP,2,8,7
/UI,MESH,OFF
ALLSEL,ALL
FLST,3,2,6,ORDE,2
FITEM,3,1
FITEM,3,-2
VSYMM,Y,P51X, , , ,0,0
NUMMRG,ALL, , , ,LOW
FINISH
/SOL
ANTYPE,4
TRNOPT,FULL
LUMPM,0
DELTIM,1e-9,0,0
OUTRES,ERASE
OUTRES,ALL,1
AUTOTS,1
BETAD,3.5e-6
TIME,4e-6
FLST,5,4,5,ORDE,4
FITEM,5,7
FITEM,5,-8
FITEM,5,18
FITEM,5,-19
ASEL,S, , ,P51X
NSLA,R,1
FLST,5,1110,1,ORDE,21
FITEM,5,2
FITEM,5,12
FITEM,5,-43
FITEM,5,397
FITEM,5,407
FITEM,5,-438
FITEM,5,18514
FITEM,5,-19004
FITEM,5,21325
FITEM,5,-21337
FITEM,5,21387
FITEM,5,22025
FITEM,5,-22037
FITEM,5,33418
FITEM,5,-33448
FITEM,5,33813
FITEM,5,-33843
FITEM,5,51979
FITEM,5,-52210
FITEM,5,52271
FITEM,5,-52502
CM,_Y,NODE
NSEL,R, , ,P51X
CM,_Y1,NODE
CMSEL,S,_Y
CMDELE,_Y
/GO
D,_Y1,PRES,0
CMDELE,_Y1
ALLSEL,ALL
FLST,5,4,5,ORDE,4
FITEM,5,1
FITEM,5,-2
FITEM,5,12
FITEM,5,-13
ASEL,S, , ,P51X
NSLA,S,1
FLST,2,1408,1,ORDE,12
FITEM,2,1
FITEM,2,-726
FITEM,2,33418
FITEM,2,-33448
FITEM,2,33459
FITEM,2,-33768
FITEM,2,33771
FITEM,2,-33801
FITEM,2,33813
FITEM,2,-33843
FITEM,2,33853
FITEM,2,-34131
/GO
D,P51X, ,0, , , ,UY, , , , ,
ALLSEL,ALL
CSYS,1
ASEL,S,LOC,X,0.1
alist, all
APLOT
FLST,2,2,5,ORDE,2
FITEM,2,4
FITEM,2,15
SFA,P51X, ,FSI
ALLSEL,ALL
*DIM,weiyi,TABLE,9,1,1, , ,
*SET,WEIYI(1,0,1) , 0
*SET,WEIYI(2,0,1) , 1.25e-007
*SET,WEIYI(2,1,1) , 0.0001
*SET,WEIYI(3,0,1) , 2.5e-007
*SET,WEIYI(4,0,1) , 3.75e-007
*SET,WEIYI(4,1,1) , -0.0001
*SET,WEIYI(5,0,1) , 5e-007
*SET,WEIYI(6,0,1) , 6.25e-007
*SET,WEIYI(6,1,1) , 0.0001
*SET,WEIYI(7,0,1) , 7.5e-007
*SET,WEIYI(8,0,1) , 8.75e-007
*SET,WEIYI(8,1,1) , -0.0001
*SET,WEIYI(9,0,1) , 1e-006
CSYS,0
NSEL,S,LOC,X,0
NSEL,R,LOC,Y,0.11
NSEL,R,LOC,Z,0.25
NPLOT
FLST,2,1,1,ORDE,1
FITEM,2,1584
/GO
D,P51X, , %WEIYI% , , , ,UY, , , , ,
ALLSEL,ALL
EPLOT
FINISH
! /EXIT,ALL
 楼主| 发表于 2012-3-19 11:06 | 显示全部楼层
由于本人初学,不会用命令流,所以给您们各位来宾带来不便,深表歉意
发表于 2012-3-28 15:51 | 显示全部楼层
表示我一直用的ansys10.0
GMT+8, 2025-1-11 03:52 , Processed in 0.055820 second(s), 17 queries , Gzip On.
