查看: 3776|回复: 3
[编程技巧] 关于求解马尔科夫链的平稳分布,大牛进!!!
发表于 2012-3-18 10:44 | 显示全部楼层 |阅读模式
知道马尔科夫链的转移流量图,如何求解马尔科夫链的平稳分布?或者说,知道N*N矩阵中各元素之间的关系,如何求各元素的值?在线等。。。。。。
例如:状态(i,j),0<i,j<N,转移流程图如下:
发表于 2012-11-15 17:29 | 显示全部楼层
发表于 2012-11-28 15:47 | 显示全部楼层
一个马尔科夫链的matlab程序
  1. function [chain,state]=markov(T,n,s0,V);
  2. %function [chain,state]=markov(T,n,s0,V);
  3. %  chain generates a simulation from a Markov chain of dimension
  4. %  the size of T
  5. %
  6. %  T is transition matrix
  7. %  n is number of periods to simulate
  8. %  s0 is initial state (initial probabilities)
  9. %  V is the quantity corresponding to each state
  10. %  state is a matrix recording the number of the realized state at time t
  11. %
  12. % Original author: Tom Sargent
  13. % Comments added by Qiang Chen
  14. [r c]=size(T);   % r is # of rows, c is # of columns of T
  15. if nargin == 1;  % "nargin" refers to "number of arguments in". So only T is provided in this case
  16.   V=[1:r];
  17.   s0=1;
  18.   n=100;
  19. end;
  20. if nargin == 2;  % both T and n are provided
  21.   V=[1:r];
  22.   s0=1;
  23. end;
  24. if nargin == 3;  % T, n and S0 are provided
  25.   V=[1:r];
  26. end;
  27. % check if the transition matrix T is square
  28. if r ~= c;
  29.   disp('error using markov function');
  30.   disp('transition matrix must be square');
  31.   return;  % break the program and return
  32. end;
  33. % check if each row of T sums up to 1
  34. for k=1:r;
  35.   if sum(T(k,:)) ~= 1;
  36.    disp('error using markov function')
  37.     disp(['row ',num2str(k),' does not sum to one']);  % "num2str" converts numbers to a string.
  38.     disp(' it sums to :');
  39.     disp([ sum(T(k,:)) ]);
  40.     disp(['normalizing row ',num2str(k),'']);
  41.     T(k,:)=T(k,:)/sum(T(k,:));
  42.   end;
  43. end;
  44. [v1 v2]=size(V);
  45. if v1 ~= 1 | v2 ~=r   % "|" means "or"
  46.   disp('error using markov function');
  47.   disp(['state value vector V must be 1 x ',num2str(r),''])
  48.   if v2 == 1 &v2 == r;
  49.     disp('transposing state valuation vector');
  50.     V=V';  % change it to a column vector
  51.   else;
  52.     return;
  53.   end;
  54. end
  55. if s0 < 1 |s0 > r;
  56.   disp(['initial state ',num2str(s0),' is out of range']);
  57.   disp(['initial state defaulting to 1']);
  58.   s0=1;
  59. end;
  60. % The simulation of Markov chain formally starts from here
  61. %T
  62. %rand('uniform');
  63. X=rand(n-1,1);  % generate (n-1) random numbers drawn from uniform distribution on [0,1], each number to be used in one simulation.
  64. s=zeros(r,1);   % initiate the state vector "s" to be a rx1 zero vector
  65. s(s0)=1;        % change the "s0"th element of "s" to 1
  66. cum=T*triu(ones(size(T)));
  67. % "triu(ones(size(T)))" generates an upper triangular matrix with all elements equal to 1
  68. % cum is a rxr matrix whose ith column is the cumulative sum from the 1st column to the ith column
  69. % the ith row of cum is the cumulative distribution for the next period given the current state.
  70. for k=1:length(X);  % "length(X)" returns the size of the longest dimension of X. "k" indicates the kth simulation.
  71.
  72.   state(:,k)=s;     % state is a matrix recording the number of the realized state at time k
  73.
  74.   ppi=[0 s'*cum];   % this is the conditional cumulative distribution for the next period given the current state s
  75.
  76.   s=((X(k)<=ppi(2:r+1)).*(X(k)>ppi(1:r)))';
  77.   % compares each element of ppi(2:r+1) or ppi(1:r) with a scalar X(k), and
  78.   % returns 1 if the inequality holds and 0 otherwise
  79.   % this formula assigns 1 when both inequalities hold, and 0 otherwise
  80.
  81. end;
  82. chain=V*state;
发表于 2013-11-29 16:30 | 显示全部楼层
我想问一下这个转移流量图是怎么建立的啊?
GMT+8, 2025-1-17 10:44 , Processed in 0.065677 second(s), 22 queries , Gzip On.
