查看: 1435|回复: 0
[前后处理] 用质量-弹簧单元模拟车桥耦合时程分析问题
发表于 2012-3-16 09:21 | 显示全部楼层 |阅读模式
建立箱型梁模型,用shell63单元划分网格,梁两端简支约束。想用生死单元法模拟列车通过桥梁。所以在梁上部0.5m处建了mass21单元(6个自由度,竖直方向上定义mass值),与箱型梁顶板相应节点连接,建立弹簧单元combin14(3维).
*** WARNING ***                         CP =     372.750   TIME= 21:36:34
There are 186 small equation solver pivot terms.
*** WARNING ***                         CP =     374.953   TIME= 21:36:37
The calculated reference FORCE CONVERGENCE VALUE = 0 is less than 1E-2
a threshold zero, A value of 1E-2 or specified MINREF is used.  Check
results carefully.
结果里,位移全部为0.
应该怎么解决呢。
. 建议问题描述应该具体...  发表于 2012-3-16 11:05
GMT+8, 2025-1-11 05:07 , Processed in 0.066046 second(s), 18 queries , Gzip On.
