查看: 2325|回复: 1
[控制系统类] 模糊控制仿真中,时间停止的问题
发表于 2012-3-7 19:29 | 显示全部楼层 |阅读模式
各位大哥大姐,偶设计完一模糊控制器,然后用simulink进行仿真,出现下述问题:At time 1.052408466505969, simulation hits (1000) consecutive zero crossings. Consecutive zero crossings will slow down the simulation. A report is shown below. You may increase the number of consecutive zero crossings allowed in the solver diagnostic controls to continue the simulation and ignore this message or disable the zero crossing detection of some of the blocks to accelerate the simulation.
No. of Consecutive Zcs |         Block type         |     Block path
                  2000                       MinMax     "firstfangzhen/Fuzzy Logic  Controller/FIS Wizard/Rule9/impMethod"
                  1000                       MinMax     "firstfangzhen/Fuzzy Logic  Controller/FIS Wizard/Rule10/impMethod"
                     2                       MinMax     "firstfangzhen/Fuzzy Logic  Controller/FIS Wizard/Rule13/impMethod"
这是我复制别人的帖子,但是我的也是同样的问题,不同的就是RULE后的数字不同而已,急求
发表于 2012-12-10 17:06 | 显示全部楼层
configuration 把各种检测都关了
要么你的论域 比例因子不对
GMT+8, 2024-11-24 22:25 , Processed in 0.059807 second(s), 18 queries , Gzip On.
