查看: 10712|回复: 3
[Fluent应用] 刚开始迭代时,遇到absolute pressure limited on zone 2
发表于 2012-3-7 14:46 | 显示全部楼层 |阅读模式
我算的是叶轮机械的流场,8个靜叶加配合上12个动叶,总网格数大约400万多,我的机器是8G内存,I5的处理器,四核的,初始化后,我开始迭代,一步也迭代不下去,网格质量应该没啥问题啊,我在Gambit中建模时都检查过了。出现了下列错误:
absolute pressure limited to 1.000000e+000 in 1081046 cells on zone 2
temperature limited to 1.000000e+000 in 1081046 cells on zone 2
absolute pressure limited to 1.000000e+000 in 3075599 cells on zone 3
temperature limited to 1.000000e+000 in 3075599 cells on zone 3
  iter continuity x-velocity y-velocity z-velocity     energy          k    epsilon     time/iter
time step reduced in 89159 cells
absolute pressure limited to 1.000000e+000 in 419282 cells on zone 2
temperature limited to 1.000000e+000 in 398444 cells on zone 2
absolute pressure limited to 1.000000e+000 in 1323303 cells on zone 3
temperature limited to 1.000000e+000 in 1316710 cells on zone 3
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 63640 cells
Error: Floating point error: invalid number
,求各位大侠不吝赐教啊,论文做不下去了,查了好多资料,这个问题解决不了,着急啊!!!!
 楼主| 发表于 2012-3-7 19:49 | 显示全部楼层
跪求回复啊
发表于 2012-3-8 07:30 | 显示全部楼层
回复 2 # skgk-qqq 的帖子
你说网格质量没问题。怎么判断的?简单check grid是不够的。
我以前回答过一些问题,有一篇帖子做了个小结,你可以参考一下,看看有没有什么帮助:
http://forum.vibunion.com/thread-109619-1-1.html
 楼主| 发表于 2012-3-8 07:42 | 显示全部楼层
我不是简单check了啊,在Gambit中将网格检查了,好的,谢谢你,我刚才查看了那个链接,我会按照那个要求,再试试。
GMT+8, 2024-11-28 23:37 , Processed in 0.055062 second(s), 17 queries , Gzip On.
