查看: 1207|回复: 1
求助:请帮我看看应该怎么改(急)
发表于 2006-4-18 17:11 | 显示全部楼层 |阅读模式
<P><STRONG>我用matcom把m文件编译成.exe文件如下:<BR></STRONG>#line 1 "c:/matcom45/新建文件夹/linennet_143.m"<BR>  dMm(P); dMm(T); dMm(w_range); dMm(b_range); dMm(ES); dMm(w); dMm(b); dMm(A); dMm(E); dMm(SSE); dMm(p); dMm(a);  \ <BR>  #line 2 "c:/matcom45/新建文件夹/linennet_143.m"<BR>  call_stack_begin;<BR>  #line 2 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ clf(TM("reset"));<BR>  #line 3 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display( figure((CL(gcf()))) );<BR>  #line 4 "c:/matcom45/新建文件夹/linennet_143.m"<BR>  //setfsize(300,300);<BR>  #line 5 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ echo(TM("on"));<BR>  mt_print_handler("clc\n");<BR>  #line 6 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(clc());<BR>  mt_print_handler("\n");<BR>  <BR>  mt_print_handler("% INITLIN -对神经元的权值和阈值进行初始化\n");<BR>  #line 8 "c:/matcom45/新建文件夹/linennet_143.m"<BR>  // INITLIN -对神经元的权值和阈值进行初始化<BR>  mt_print_handler("% SIMULIN -对神经元进行仿真\n");<BR>  #line 9 "c:/matcom45/新建文件夹/linennet_143.m"<BR>  // SIMULIN -对神经元进行仿真<BR>  mt_print_handler("% TRAINWH -利用神经元学习规则对线性神经元训练\n");<BR>  #line 10 "c:/matcom45/新建文件夹/linennet_143.m"<BR>  // TRAINWH -利用神经元学习规则对线性神经元训练<BR>  mt_print_handler("pause  \n");<BR>  #line 11 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(pauseM());<BR>  mt_print_handler("clc\n");<BR>  #line 12 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(clc());<BR>  mt_print_handler("% P 为输入向量\n");<BR>  #line 13 "c:/matcom45/新建文件夹/linennet_143.m"<BR>  // P 为输入向量<BR>  mt_print_handler("P=[1.0 -1.2];\n");<BR>  #line 14 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ P = (BR(1.0),-1.2);<BR>  mt_print_handler("% T 为目标向量\n");<BR>  #line 15 "c:/matcom45/新建文件夹/linennet_143.m"<BR>  // T 为目标向量<BR>  mt_print_handler("T = [0.5 1.0];\n");<BR>  #line 16 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ T = (BR(0.5),1.0);<BR>  mt_print_handler("pause \n");<BR>  #line 17 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(pauseM());<BR>  mt_print_handler("clc\n");<BR>  #line 18 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(clc());<BR>  mt_print_handler("\n");<BR>  <BR>  mt_print_handler("w_range=-1:0.1:1;\n");<BR>  #line 20 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ w_range = colon(-1.0,0.1,1.0);<BR>  mt_print_handler("b_range=-1:0.1:1;\n");<BR>  #line 21 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ b_range = colon(-1.0,0.1,1.0);<BR>  mt_print_handler("ES=errsurf(P,T,w_range,b_range,'purelin');\n");<BR>  #line 22 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ ES = errsurf(P,T,w_range,b_range,TM("purelin"));<BR>  mt_print_handler("plotes(w_range,b_range,ES);\n");<BR>  #line 23 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ plotes(w_range,b_range,ES);<BR>  mt_print_handler("pause\n");<BR>  #line 24 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(pauseM());<BR>  mt_print_handler("clc\n");<BR>  #line 25 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(clc());<BR>  mt_print_handler("\n");<BR>  <BR>  mt_print_handler("% 初始化权值和阈值\n");<BR>  #line 27 "c:/matcom45/新建文件夹/linennet_143.m"<BR>  // 初始化权值和阈值<BR>  mt_print_handler("[w,b]=solvelin(P,T);");<BR>  #line 28 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ /*[w,b] = */solvelin(P,T,i_o,w,b);<BR>  mt_print_handler(" \n");<BR>  <BR>  mt_print_handler("\n");<BR>  <BR>  mt_print_handler("pause\n");<BR>  #line 30 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(pauseM());<BR>  mt_print_handler("clc\n");<BR>  #line 31 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(clc());<BR>  mt_print_handler("\n");<BR>  <BR>  mt_print_handler("A=simulin(P,w,b);\n");<BR>  #line 33 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ A = simulin(P,w,b);<BR>  mt_print_handler("E=T-A;\n");<BR>  #line 34 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ E = T-A;<BR>  mt_print_handler("SSE=sumsqr(E)\n");<BR>  #line 35 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ SSE = sumsqr(E); display(SSE);<BR>  mt_print_handler("pause\n");<BR>  #line 36 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(pauseM());<BR>  mt_print_handler("clc\n");<BR>  #line 37 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(clc());<BR>  mt_print_handler("plotes(w_range,b_range,ES);\n");<BR>  #line 38 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ plotes(w_range,b_range,ES);<BR>  mt_print_handler("plotep(w,b,SSE);\n");<BR>  #line 39 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ plotep(w,b,SSE);<BR>  mt_print_handler("pause;\n");<BR>  #line 40 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ pauseM();<BR>  mt_print_handler("clc\n");<BR>  #line 41 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ display(clc());<BR>  mt_print_handler("p=-1.1;\n");<BR>  #line 42 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ p = -1.1;<BR>  mt_print_handler("a=simulin(p,w,b)\n");<BR>  #line 43 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ a = simulin(p,w,b); display(a);<BR>  mt_print_handler("echo off\n");<BR>  #line 44 "c:/matcom45/新建文件夹/linennet_143.m"<BR>_ echo(TM("off"));<BR>  call_stack_end;<BR><BR><STRONG>添加到Vc++工程后编译出现如下错误提示:<BR></STRONG>--------------------Configuration: linennet - Win32 Debug--------------------<BR>Compiling resources...<BR>Compiling...<BR>StdAfx.cpp<BR>Compiling...<BR>linennet.cpp<BR>linennetDlg.cpp<BR>errsurf.cpp<BR>feval.cpp<BR>linennet_143.cpp<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'P' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'T' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'w_range' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'b_range' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'ES' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'w' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'b' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'A' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'E' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'SSE' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'p' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2065: 'a' : undeclared identifier<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'dMm' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2086: 'dMm' : redefinition<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: 'call_stack_begin' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2146: syntax error : missing ';' before identifier 'clf'<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : error C2501: '_' : missing storage-class or type specifiers<BR>c:/matcom45/新建文件夹/linennet_143.m(2) : fatal error C1004: unexpected end of file found<BR>nntobsf.cpp<BR>nntobsu.cpp<BR>plotep.cpp<BR>plotes.cpp<BR>purelin.cpp<BR>simulin.cpp<BR>solvelin.cpp<BR>sumsqr.cpp<BR>Error executing cl.exe.</P>
<P>linennet.exe - 39 error(s), 0 warning(s)<BR><BR><STRONG>请帮我看看,是什么错误,应该怎么改?不胜感激</STRONG></P>
发表于 2006-5-3 15:54 | 显示全部楼层
晕!
还是晕
GMT+8, 2025-1-18 20:58 , Processed in 0.057142 second(s), 17 queries , Gzip On.
