查看: 2556|回复: 5
[分形与混沌] 请教高手:这个非线性方程组该如何求解?
发表于 2006-4-18 10:47 | 显示全部楼层 |阅读模式
<P>方程如下:<BR>mx<SUP>''</SUP>+cx<SUP>'</SUP>+∑k(x*cos(θ<SUB>i</SUB>)+y*sin(θ<SUB>i</SUB>))<SUP>1.5</SUP>*cos((θ<SUB>i</SUB>)=W+F<SUB>u</SUB>cos(wt)<BR>my<SUP>''</SUP>+cy<SUP>'</SUP>+∑k(x*cos(θ<SUB>i</SUB>)+y*sin(θ<SUB>i</SUB>))<SUP>1.5</SUP>*sin((θ<SUB>i</SUB>)=F<SUB>u</SUB>cos(wt)<BR>式中m,c,k,W,Fu,w都是已知,θ<SUB>i</SUB>=2*π*(i-1)/z+Wc*t,z,Wc也是已知。<BR>在matlab下编写的程序如下:<BR>xdot=[x(2);(Fx+Fu*cos(w*t)-c*x2-sum((ko*(x(1)*cos(ai)+x(3)*sin(az)).^1.5).cos(az)))/m;...<BR>        x(4);(Fy+Fu*sin(w*t)-c*x2-sum((ko*(x(1)*cos(ai)+x(3)*sin(az)).^1.5).sin(az)))/m]<BR>然后用ode45求解,这样编写是否正确?<BR><BR></P>
发表于 2006-4-19 21:59 | 显示全部楼层
it is suggested that the simultanous  equations 'd better be storaged in one dependent file; and usually it is expressed in the form of the state equations; then empoly the ode45 or other functions to solve the equations
发表于 2006-4-20 19:12 | 显示全部楼层
<DIV class=quote><B>以下是引用<I>vicky_boy</I>在2006-4-18 10:47:34的发言:</B><br>
<P>方程如下:<br>mx<SUP>''</SUP>+cx<SUP>'</SUP>+∑k(x*cos(θ<SUB>i</SUB>)+y*sin(θ<SUB>i</SUB>))<SUP>1.5</SUP>*cos((θ<SUB>i</SUB>)=W+F<SUB>u</SUB>cos(wt)<br>my<SUP>''</SUP>+cy<SUP>'</SUP>+∑k(x*cos(θ<SUB>i</SUB>)+y*sin(θ<SUB>i</SUB>))<SUP>1.5</SUP>*sin((θ<SUB>i</SUB>)=F<SUB>u</SUB>cos(wt)<br>式中m,c,k,W,Fu,w都是已知,θ<SUB>i</SUB>=2*π*(i-1)/z+Wc*t,z,Wc也是已知。<br>在matlab下编写的程序如下:<br>xdot=[x(2);(Fx+Fu*cos(w*t)-c*<FONT color=#ff3300 size=5>x(2)</FONT>-sum((ko*(x(1)*cos(ai)+x(3)*sin(az)).^1.5).cos(az)))/m;...<br>        x(4);(Fy+Fu*sin(w*t)-c*<FONT color=#ff0000 size=5>X(4)</FONT>-sum((ko*(x(1)*cos(ai)+x(3)*sin(az)).^1.5).sin(az)))/m]<br>然后用ode45求解,这样编写是否正确?<br><br></P></DIV>
<P>X=X(1);X'=X(2)<br>Y=X(3);Y'=X(4)<br><br>然后编写xdot=[dx;dx';dy;dy']就可以了</P>
[此贴子已经被作者于2006-4-20 19:13:12编辑过]
 楼主| 发表于 2006-4-23 15:07 | 显示全部楼层
回复:(flybaly)以下是引用vicky_boy在2006-4-18 10...
<P>这个错误我已经改过来了,但还是不行,错误还是一样的<BR>是不是sum用的不对?</P>
 楼主| 发表于 2006-4-23 15:09 | 显示全部楼层
错误为:")" expected, "." found,不得其解
发表于 2006-4-23 19:40 | 显示全部楼层
回复:(vicky_boy)回复:(flybaly)以下是引用vick...
<DIV class=quote><B>以下是引用<I>vicky_boy</I>在2006-4-23 15:09:08的发言:</B><br>错误为:")" expected, "." found,不得其解</DIV><br>呵呵,cos(az)和sin(az)前少了乘号了<br>认真检查检查吧
[此贴子已经被作者于2006-4-23 19:41:23编辑过]
GMT+8, 2025-1-10 21:20 , Processed in 0.093493 second(s), 17 queries , Gzip On.
