查看: 14496|回复: 2
[CFD及热分析] 执行 CFX solver 出现错误讯息 code 255 ?????
发表于 2012-1-4 19:13 | 显示全部楼层 |阅读模式
请教高手如何解决????
The ANSYS CFX solver could not be started, or exited with return code 255:
.  No results file has been created.
  This run of the CFX-14.0 Solver started at 08:37:39 on 04 Jan 2012 by
user user on USER-PC (intel_xeon64.sse2_winnt) using the command:
  "D:\Program Files\ANSYS Inc\v140\CFX\bin\perllib\cfx5solve.pl" -batch
    -ccl runInput.ccl -fullname "Fluid Flow CFX_006"
Setting up CFX Solver run ...
|                    CFX Command Language for Run                    |
LIBRARY:
   CEL:
     EXPRESSIONS:
       windspeedl = 10 [m s^-1]
     END
   END
   MATERIAL: Air at 25 C
     Material Description = Air at 25 C and 1 atm (dry)
     Material Group = Air Data, Constant Property Gases
     Option = Pure Substance
     Thermodynamic State = Gas
     PROPERTIES:
       Option = General Material
       EQUATION OF STATE:
         Density = 1.185 [kg m^-3]
         Molar Mass = 28.96 [kg kmol^-1]
         Option = Value
       END
       SPECIFIC HEAT CAPACITY:
         Option = Value
         Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
         Specific Heat Type = Constant Pressure
       END
       REFERENCE STATE:
         Option = Specified Point
         Reference Pressure = 1 [atm]
         Reference Specific Enthalpy = 0. [J/kg]
         Reference Specific Entropy = 0. [J/kg/K]
         Reference Temperature = 25 [C]
       END
       DYNAMIC VISCOSITY:
         Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
         Option = Value
       END
       THERMAL CONDUCTIVITY:
         Option = Value
         Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
       END
       ABSORPTION COEFFICIENT:
         Absorption Coefficient = 0.01 [m^-1]
         Option = Value
       END
       SCATTERING COEFFICIENT:
         Option = Value
         Scattering Coefficient = 0.0 [m^-1]
       END
       REFRACTIVE INDEX:
         Option = Value
         Refractive Index = 1.0 [m m^-1]
       END
       THERMAL EXPANSIVITY:
         Option = Value
         Thermal Expansivity = 0.003356 [K^-1]
       END
     END
   END
END
FLOW: Flow Analysis 1
   SOLUTION UNITS:
     Angle Units = [rad]
     Length Units = [m]
     Mass Units = [kg]
     Solid Angle Units = [sr]
     Temperature Units = [K]
     Time Units =
   END
   ANALYSIS TYPE:
     Option = Steady State
     EXTERNAL SOLVER COUPLING:
       Option = None
     END
   END
   DOMAIN: air
     Coord Frame = Coord 0
     Domain Type = Fluid
     Location = B6
     BOUNDARY: air Default
       Boundary Type = WALL
       Location = F2459.6,F2461.6
       BOUNDARY CONDITIONS:
         MASS AND MOMENTUM:
           Option = No Slip Wall
         END
         WALL ROUGHNESS:
           Option = Smooth Wall
         END
       END
     END
     BOUNDARY: bottom
       Location = bottom
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: inlet
       Boundary Type = INLET
       Location = inlet
         FLOW REGIME:
           Option = Subsonic
         END
         MASS AND MOMENTUM:
           Normal Speed = windspeedl
           Option = Normal Speed
         END
         TURBULENCE:
           Option = Medium Intensity and Eddy Viscosity Ratio
         END
       END
     END
     BOUNDARY: outlet
       Boundary Type = OUTLET
       Location = outlet
         FLOW REGIME:
           Option = Subsonic
         END
         MASS AND MOMENTUM:
           Option = Average Static Pressure
           Pressure Profile Blend = 0.05
           Relative Pressure = 0 [Pa]
         END
         PRESSURE AVERAGING:
           Option = Average Over Whole Outlet
         END
       END
     END
     BOUNDARY: qiq
       Location = n101
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: symm
       Boundary Type = SYMMETRY
       Location = symm
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
         Option = Non Buoyant
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
     FLUID DEFINITION: Fluid 1
       Material = Air at 25 C
       Option = Material Library
       MORPHOLOGY:
         Option = Continuous Fluid
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
       HEAT TRANSFER MODEL:
         Fluid Temperature = 25 [C]
         Option = Isothermal
       END
       THERMAL RADIATION MODEL:
         Option = None
       END
       TURBULENCE MODEL:
         Option = k epsilon
       END
       TURBULENT WALL FUNCTIONS:
         Option = Scalable
       END
     END
   END
   OUTPUT CONTROL:
     RESULTS:
       File Compression Level = Default
       Option = Standard
     END
   END
   SOLVER CONTROL:
     Turbulence Numerics = First Order
     ADVECTION SCHEME:
       Option = High Resolution
     END
     CONVERGENCE CONTROL:
       Length Scale Option = Conservative
       Maximum Number of Iterations = 100
       Minimum Number of Iterations = 1
       Timescale Control = Auto Timescale
       Timescale Factor = 1.0
     END
     CONVERGENCE CRITERIA:
       Residual Target = 1.E-4
       Residual Type = RMS
     END
     DYNAMIC MODEL CONTROL:
       Global Dynamic Model Control = On
     END
   END
END
COMMAND FILE:
   Version = 14.0
   Results Version = 14.0
END
PARAMETERIZATION:
   INPUT FIELD: windspeedl
     Expression Name = windspeedl
     Method = Expression
   END
END
SIMULATION CONTROL:
   EXECUTION CONTROL:
     EXECUTABLE SELECTION:
       Double Precision = Off
     END
     INTERPOLATOR STEP CONTROL:
       Runtime Priority = Standard
       MEMORY CONTROL:
         Memory Allocation Factor = 1.0
       END
     END
     PARALLEL HOST LIBRARY:
       HOST DEFINITION: userpc
         Remote Host Name = USER-PC
         Host Architecture String = winnt
         Installation Root = D:\Program Files\ANSYS Inc\v%v\CFX
       END
     END
     PARTITIONER STEP CONTROL:
       Multidomain Option = Independent Partitioning
         Use Large Problem Partitioner = Off
       END
       MEMORY CONTROL:
       END
       PARTITIONING TYPE:
         MeTiS Type = k-way
         Option = MeTiS
         Partition Size Rule = Automatic
         Partition Weight Factors = 0.50000, 0.50000
       END
     END
     RUN DEFINITION:
       Run Mode = Full
       Solver Input File = Fluid Flow CFX.def
     END
     SOLVER STEP CONTROL:
       MEMORY CONTROL:
       END
       PARALLEL ENVIRONMENT:
         Number of Processes = 2
         Start Method = Platform MPI Local Parallel
         Parallel Host List = userpc*2
       END
     END
   END
END
|                            Partitioning                            |
|                  ANSYS(R) CFX(R) Partitioner 14.0                  |
| Version 2011.10.10-23.02            Tue Oct 11 00:09:32 GMTST 2011 |
|                        Executable Attributes                       |
| single-int32-32bit-novc8-noifort-novc6-optimised-supfort-noprof-nos|
| (C) 2011 ANSYS, Inc.                                               |
| All rights reserved. Unauthorized use, distribution or duplication |
| is prohibited. This product is subject to U.S. laws governing      |
| export and re-export. For full Legal Notice, see documentation.    |
|                          Job Information                           |
Run mode:       partitioning run
Host computer:  USER-PC (PID:660)
Job started:    Wed Jan 04 08:37:42 2012
|        Memory Allocated for Run  (Actual usage may be less)        |
  Data Type      Kwords  Words/Node  Words/Elem      Kbytes Bytes/Node
  Real           1174.3       31.77        5.64      4587.0     127.07
  Integer        4720.7      127.70       22.66     18440.4     510.82
  Character      3192.5       86.36       15.32      3117.6      86.36
  Logical          80.0        2.16        0.38       312.5       8.66
  Double          600.5       16.24        2.88      4691.4     129.96
|                          Mesh Statistics                           |
Domain Name : air
     Total Number of Nodes                                =       36966
     Total Number of Elements                             =      208366
         Total Number of Tetrahedrons                     =      208366
     Total Number of Faces                                =        8806
|                     Vertex Based Partitioning                      |
Partitioning of domain: air
- Partitioning tool:       MeTiS multilevel k-way algorithm
- Number of partitions:             2
- Number of graph-nodes:        36966
- Number of graph-edges:       499468
|                      Partitioning Information                      |
Partitioning information for domain: air
        |     Elements     |        Vertices        |     Faces       |
| Part |   Number     %   |   Number     %   %Ovlp |  Number     %   |
| Full |    208366        |     36966              |     8806        |
|    1 |    107424   50.3 |     19946   51.4   4.6 |     6166   69.5 |
|    2 |    106187   49.7 |     18890   48.6   5.0 |     2704   30.5 |
| Sum  |    213611  100.0 |     38836  100.0   4.8 |     8870  100.0 |
|                 Partitioning CPU-Time Requirements                 |
- Preparations                                       1.330E-01 seconds
- Low-level mesh partitioning                        3.500E-02 seconds
- Global partitioning information                    1.700E-02 seconds
- Element and face partitioning information          2.000E-02 seconds
- Vertex partitioning information                    3.000E-03 seconds
- Partitioning information compression               2.000E-03 seconds
- Summed CPU-time for mesh partitioning              2.400E-01 seconds
|                          Job Information                           |
Job finished:   Wed Jan 04 08:37:43 2012
Total CPU time: 7.850E-01 seconds
             or: (          0:         0:         0:     0.785 )
                 (       Days:     Hours:   Minutes:   Seconds )
Total wall clock time: 1.000E+00 seconds
             or: (          0:         0:         0:     1.000 )
|                               Solver                               |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver could not be started, or exited with return   |
| code 255: .  No results file has been created.                     |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
发表于 2012-12-12 13:42 | 显示全部楼层
是不是 interface的原因
发表于 2012-12-12 15:07 | 显示全部楼层
很可能是网格问题,特别是交界面的网格
GMT+8, 2025-1-10 01:46 , Processed in 0.070274 second(s), 22 queries , Gzip On.
