查看: 1367|回复: 0
[HHT] emd工具箱安装时出现的问题
发表于 2011-12-18 21:27 | 显示全部楼层 |阅读模式
小弟刚接触HHT不久,用matlab R2009a 安装emd工具箱式出现了错误,请哪位兄弟帮忙解释下什么原因,万分感谢!!
lcc preprocessor error: cemdc.c:19 Could not find include file <complex.h>
Error cemdc.c: .\cio.h: 31  syntax error; found `*' expecting `;'
Error cemdc.c: .\cio.h: 31  skipping `*' `y'
Error cemdc.c: .\cio.h: 39  syntax error; found `*' expecting `;'
Error cemdc.c: .\cio.h: 39  skipping `*' `pointer'
Error cemdc.c: .\cio.h: 53  syntax error; found `*' expecting `)'
Error cemdc.c: .\cio.h: 53  skipping `*' `,'
Error cemdc.c: .\cio.h: 53  missing name for parameter 1 to function `add_imf'
Error cemdc.c: .\cio.h: 53  syntax error; found `int' expecting `{'
Error cemdc.c: .\cio.h: 53  empty declaration
Error cemdc.c: .\cio.h: 53  syntax error; found `)' expecting `;'
Error cemdc.c: .\cio.h: 53  skipping `)'
Error cemdc.c: .\cextr.h: 28  syntax error; found `*' expecting `)'
Error cemdc.c: .\cextr.h: 28  skipping `*' `,'
Error cemdc.c: .\cextr.h: 28  syntax error; found `double' expecting `;'
Error cemdc.c: .\cextr.h: 28  empty declaration
Error cemdc.c: .\cextr.h: 28  syntax error; found `,' expecting `;'
Error cemdc.c: .\cextr.h: 28  skipping `,'
Error cemdc.c: .\cextr.h: 28  too many errors
  D:\PROGRA~1\MATLAB\R2009A\BIN\MEX.PL: Error: Compile of 'cemdc.c' failed.
lcc preprocessor error: cemdc_fix.c:19 Could not find include file <complex.h>
Error cemdc_fix.c: .\cio_fix.h: 27  syntax error; found `*' expecting `;'
Error cemdc_fix.c: .\cio_fix.h: 27  skipping `*' `y'
Error cemdc_fix.c: .\cio_fix.h: 34  syntax error; found `*' expecting `;'
Error cemdc_fix.c: .\cio_fix.h: 34  skipping `*' `pointer'
Error cemdc_fix.c: .\cio_fix.h: 48  syntax error; found `*' expecting `)'
Error cemdc_fix.c: .\cio_fix.h: 48  skipping `*' `,'
Error cemdc_fix.c: .\cio_fix.h: 48  missing name for parameter 1 to function `add_imf'
Error cemdc_fix.c: .\cio_fix.h: 48  syntax error; found `int' expecting `{'
Error cemdc_fix.c: .\cio_fix.h: 48  empty declaration
Error cemdc_fix.c: .\cio_fix.h: 48  syntax error; found `)' expecting `;'
Error cemdc_fix.c: .\cio_fix.h: 48  skipping `)'
Error cemdc_fix.c: .\cextr.h: 28  syntax error; found `*' expecting `)'
Error cemdc_fix.c: .\cextr.h: 28  skipping `*' `,'
Error cemdc_fix.c: .\cextr.h: 28  syntax error; found `double' expecting `;'
Error cemdc_fix.c: .\cextr.h: 28  empty declaration
Error cemdc_fix.c: .\cextr.h: 28  syntax error; found `,' expecting `;'
Error cemdc_fix.c: .\cextr.h: 28  skipping `,'
Error cemdc_fix.c: .\cextr.h: 28  too many errors
  D:\PROGRA~1\MATLAB\R2009A\BIN\MEX.PL: Error: Compile of 'cemdc_fix.c' failed.
lcc preprocessor error: cemdc2.c:19 Could not find include file <complex.h>
Error cemdc2.c: .\cio.h: 31  syntax error; found `*' expecting `;'
Error cemdc2.c: .\cio.h: 31  skipping `*' `y'
Error cemdc2.c: .\cio.h: 39  syntax error; found `*' expecting `;'
Error cemdc2.c: .\cio.h: 39  skipping `*' `pointer'
Error cemdc2.c: .\cio.h: 53  syntax error; found `*' expecting `)'
Error cemdc2.c: .\cio.h: 53  skipping `*' `,'
Error cemdc2.c: .\cio.h: 53  missing name for parameter 1 to function `add_imf'
Error cemdc2.c: .\cio.h: 53  syntax error; found `int' expecting `{'
Error cemdc2.c: .\cio.h: 53  empty declaration
Error cemdc2.c: .\cio.h: 53  syntax error; found `)' expecting `;'
Error cemdc2.c: .\cio.h: 53  skipping `)'
Error cemdc2.c: .\clocal_mean2.h: 23  syntax error; found `*' expecting `)'
Error cemdc2.c: .\clocal_mean2.h: 23  skipping `*' `,'
Error cemdc2.c: .\clocal_mean2.h: 23  syntax error; found `double' expecting `;'
Error cemdc2.c: .\clocal_mean2.h: 23  redeclaration of `complex' previously declared at .\cio.h 53
Error cemdc2.c: .\clocal_mean2.h: 23  syntax error; found `*' expecting `;'
Error cemdc2.c: .\clocal_mean2.h: 23  illegal expression
Error cemdc2.c: .\clocal_mean2.h: 23  type error: pointer expected
Warning cemdc2.c: .\clocal_mean2.h: 23  Statement has no effect
Error cemdc2.c: .\clocal_mean2.h: 23  too many errors
  D:\PROGRA~1\MATLAB\R2009A\BIN\MEX.PL: Error: Compile of 'cemdc2.c' failed.
lcc preprocessor error: cemdc2_fix.c:19 Could not find include file <complex.h>
Error cemdc2_fix.c: .\cio_fix.h: 27  syntax error; found `*' expecting `;'
Error cemdc2_fix.c: .\cio_fix.h: 27  skipping `*' `y'
Error cemdc2_fix.c: .\cio_fix.h: 34  syntax error; found `*' expecting `;'
Error cemdc2_fix.c: .\cio_fix.h: 34  skipping `*' `pointer'
Error cemdc2_fix.c: .\cio_fix.h: 48  syntax error; found `*' expecting `)'
Error cemdc2_fix.c: .\cio_fix.h: 48  skipping `*' `,'
Error cemdc2_fix.c: .\cio_fix.h: 48  missing name for parameter 1 to function `add_imf'
Error cemdc2_fix.c: .\cio_fix.h: 48  syntax error; found `int' expecting `{'
Error cemdc2_fix.c: .\cio_fix.h: 48  empty declaration
Error cemdc2_fix.c: .\cio_fix.h: 48  syntax error; found `)' expecting `;'
Error cemdc2_fix.c: .\cio_fix.h: 48  skipping `)'
Error cemdc2_fix.c: .\clocal_mean2.h: 23  syntax error; found `*' expecting `)'
Error cemdc2_fix.c: .\clocal_mean2.h: 23  skipping `*' `,'
Error cemdc2_fix.c: .\clocal_mean2.h: 23  syntax error; found `double' expecting `;'
Error cemdc2_fix.c: .\clocal_mean2.h: 23  redeclaration of `complex' previously declared at .\cio_fix.h 48
Error cemdc2_fix.c: .\clocal_mean2.h: 23  syntax error; found `*' expecting `;'
Error cemdc2_fix.c: .\clocal_mean2.h: 23  illegal expression
Error cemdc2_fix.c: .\clocal_mean2.h: 23  type error: pointer expected
Warning cemdc2_fix.c: .\clocal_mean2.h: 23  Statement has no effect
Error cemdc2_fix.c: .\clocal_mean2.h: 23  too many errors
  D:\PROGRA~1\MATLAB\R2009A\BIN\MEX.PL: Error: Compile of 'cemdc2_fix.c' failed.
Warning: <complex.h> compiler extension not found. using ANSI C implementation (slower) instead for the following files:}
> In make_emdc at 41
  In install_emd at 26
cemdc.c
cemdc_fix.c
cemdc2.c
cemdc2_fix.c
Compilation successfull.
Some codes can run faster if they are compiled with a C compiler
that handles the C99 complex data type ("complex.h"). See details above.
Installation complete. Run index_emd for a list of functions.
IMPORTANT: After running INSTALL_EMD you must run the "savepath" command to save the installation
but be careful that if you previously removed parts of the path (using e.g. the "rmpath" command)
these will be permanently removed after you run "savepath"
GMT+8, 2025-1-10 11:33 , Processed in 0.076435 second(s), 19 queries , Gzip On.
