查看: 2407|回复: 0
求助:外加强环钢管混凝土柱-梁节点,梁和钢管怎么连接
发表于 2011-12-8 13:41 | 显示全部楼层 |阅读模式
做一个外加强环钢管混凝土柱-混凝土梁节点模拟,可是不太清楚梁和钢管怎么连接。我的钢管是shell,混凝土梁是实体,刚开始我用的是interaction中的surface-to-surface 定义摩擦连接,运行之后,出现的错误是
The element based surface assembly_tube-beam has a mixture of 3d shell edges and other types of underlying elements. If a surface has any 3d shell edges then all of its facets must be 3d shell edges.
The slave surface assembly_tube-beam does not exist.
我觉得是shell和实体不能连接才会造成这样的情况,是不是因为我把钢管和加强环用group以后才出现的问题?希望各位大大能帮我看看
GMT+8, 2024-12-29 16:50 , Processed in 0.091547 second(s), 22 queries , Gzip On.
