查看: 2419|回复: 1
NVH工程师 上海美资亚太研发中心 招聘
发表于 2011-10-27 11:09 | 显示全部楼层 |阅读模式
该信息已经过期
Research & Development Engineer – Air Management
Job description
Engineer needed to develop advanced fan and air management technology in Carrier AAV-IAQ group.
Candidate should have strong analytical and experimental skills in turbomachine aerodynamics and CFD modeling.
Position involves work ranging from early concept studies to production component development and implementation.
Candidate should be creative and flexible, with the ability to work on problems ranging from analytical modeling to experimental testing and facility design.
Good communication and planning skills are required.
Duties & Responsibilities:
* Develop fan & air management technology using analytical and experimental methods.
* Develop fan design and analysis methods for aerodynamics and acoustics.
* Plan, design and coordinate new fan & air management test facilities.
* Plan and supervise experimental testing and carry out data analysis and reporting.
* Generate written technical proposals and summary reports.
* Work with Carrier teams to implement advanced fan & air management designs.
* Some domestic and international travel required.
Education
MS or phD, Mechanical Engineering with emphasis on aerodynamics and turbomachinery.
Experience
2-7 years experience preferred.
* Strong fundamentals in aerodynamics and turbomachinery.
* Proficient in CFD analysis.
* Proficient in experimental methods, instrumentation, and measurement systems.
* Experience in FEA structural analysis a plus.
* Experience in part design, prototyping and fabrication is a plus.
* Background in acoustics, vibration and/or indoor air quality is a plus.
* Familiarity with HVAC&R equipment and systems a plus.
* Good communication and organization skills required.
* Industrial experience a plus, but not required.
Client: Carrier R&D Center
Key points:
1.职位属于AVV小组,主要做噪声震动分析工作,要求必须硕士以上
补充说明
开利公司是全球最大的暖通空调和冷冻设备供应商,UTC集团下公司(500强排名130,美国最大制造业16位)现上海的黄埔江观光隧道,地铁2号线,东方明珠,正大广场,香格里拉饭店和环球金融中心都是运用开利的产品。美国联合技术集团下子公司
发表于 2011-10-28 19:25 | 显示全部楼层
GMT+8, 2024-11-25 00:28 , Processed in 0.080398 second(s), 21 queries , Gzip On.
