查看: 1372|回复: 0
[结构分析] 请问各位11和12中的TUNIF 命令的区别有什么影响啊
发表于 2011-10-13 09:49 | 显示全部楼层 |阅读模式
请问各位11和12中的TUNIF 命令的区别有什么影响啊,12中多了句If using the command default to set the uniform temperature (to the reference temperature set via TREF), you can convert temperature-dependent secant coefficients of thermal expansion (SCTEs) from the definition temperature to the uniform temperature. To do so, issue the MPAMOD command.
拜托了~~
有大虾知道的不~~
GMT+8, 2025-1-27 20:15 , Processed in 0.082224 second(s), 17 queries , Gzip On.
