查看: 1444|回复: 0
[CFD及热分析] ANSYS中遇到的问题~望求解,望关注!望解释!
发表于 2011-9-29 15:35 | 显示全部楼层 |阅读模式
错误1,The calculated reference HT FLOW CONVERGENCE VALUE= 0 is less than the
default minimum of 1E-6 (which can be modified using the MINREF field
of the CNVTOL command).  Check results carefully.
做的是加温度的谐响应分析,这个错误应该导致了最后温度只有第一步存在,谐响应的后几步温度全是0了。
还是其他什么原因可能导致温度只存在于第一步不?加的温度是
Tref,27                      ! Set reference temperature
Toffst,273                  ! Set offset temperature
TUNIF,27
2,No stress stiffness matrix for element 3142 found on the EMAT file.
  Probably due to missing EMATWRITE,YES in the first load step.
关键是加了 EMATWRITE,YES 也还是出现这样的错误!
各位大虾们,请问以上的错误怎么解决呢~~
GMT+8, 2025-1-27 20:03 , Processed in 0.102965 second(s), 17 queries , Gzip On.
