查看: 1361|回复: 3
一种新的PZT通电振动方式,谁能分析一下?
发表于 2011-8-20 11:14 | 显示全部楼层 |阅读模式
原文如下: “The PZT element used in this design is polarized in the longitudinal direction. By imposing an electric differential across two opposing sides of the element, it is possible to force the element to bend via the d31 piezoelectric strain coupling. Alternatively, by applying an equal electric potential across two opposing sides of the element, with either the upper or lower longitudinal electrode grounded, the element can be forced to extend axially.”
不太明白d31压电应变耦合为什么能驱动振子的弯曲模态,我理解的应该是驱动纵向伸缩的模态;另外PZT单元两个相对面通等电压同时PZT上面或者下面接地,为什么可以驱动纵向模态?以前还真没见到过这种通电驱动方式。
图
 楼主| 发表于 2011-8-20 12:14 | 显示全部楼层
我这么理解好像也不对,再想想。有做这方面的坛友也帮忙想想哈,不甚感激!
发表于 2011-8-22 11:10 | 显示全部楼层
看不懂啊
 楼主| 发表于 2011-8-23 17:24 | 显示全部楼层
我想我已经理解了,文章里的d31是错的,应该是d51耦合产生弯曲振动。“PZT单元两个相对面通等电压同时PZT上面或者下面接地”的方式可以产生轴向压降分量,用到d33耦合,产生longitudinal振动。
GMT+8, 2025-1-10 16:39 , Processed in 0.081157 second(s), 22 queries , Gzip On.
