查看: 7592|回复: 0
[Workbench] 划分网格时出现错误
发表于 2011-8-11 09:55 | 显示全部楼层 |阅读模式
Info:The mesher restarted at a higher relevance in order to achieve a successful, quality mesh.
Error:The mesher could not determine the endpoints for the following edges.
Error:A mesh could not be generated using the current meshing options and settings. Hint: The problem geometry areas might have been highlighted. Switching to wireframe mode may make them more visible.
请问什么原因?
GMT+8, 2025-1-11 09:11 , Processed in 0.063616 second(s), 17 queries , Gzip On.
