查看: 1291|回复: 1
[结构分析] PSD分析遇到的问题
发表于 2011-8-10 21:16 | 显示全部楼层 |阅读模式
下面是建模以后进行求解时的过程~其中的FLST以后一些语句是用来选择固定结点的~而模型是通过先用PLANE42离散面,然后通过soild45拉伸成体直接离散成规则的单元的,在求解时通过ESEL,U,TYPE,,1来不求解PLANE42单元。但正是这一步导致了求解PSD时的错误。
/SOLU
ANTYPE,2
MODOPT,LANB,15
EQSLV,SPAR
MXPAND,15, , ,1
LUMPM,0
PSTRES,0
MODOPT,LANB,15,0,0, ,OFF
FLST,5,2,6,ORDE,2
FITEM,5,60
FITEM,5,-61
VSEL,S, , ,P51X
NSLV,S,1
FLST,2,648,1,ORDE,28
FITEM,2,424
FITEM,2,-425
FITEM,2,446
FITEM,2,-447
FITEM,2,468
FITEM,2,-469
FITEM,2,518
FITEM,2,-519
FITEM,2,760
FITEM,2,-913
FITEM,2,4942
FITEM,2,-4943
FITEM,2,4964
FITEM,2,-4967
FITEM,2,5008
FITEM,2,-5009
FITEM,2,5030
FITEM,2,-5033
FITEM,2,5074
FITEM,2,-5075
FITEM,2,5096
FITEM,2,-5099
FITEM,2,6160
FITEM,2,-6161
FITEM,2,6182
FITEM,2,-6185
FITEM,2,6886
FITEM,2,-7347
/GO
D,P51X, ,0, , , ,ALL, , , , ,
ALLSEL,ALL
ESEL,U,TYPE,,1
/STATUS,SOLU
SOLVE
FINISH
/SOLUTION
ANTYPE,8
SPOPT,PSD,15,1
PSDUNIT,1,ACCG,386.4,
PSDFRQ,1, ,20,1000,4000,5000,
PSDVAL,1,0.01,0.02,0.02,0.01,
FLST,5,2,6,ORDE,2
FITEM,5,60
FITEM,5,-61
VSEL,S, , ,P51X
NSLV,S,1
FITEM,2,424
FITEM,2,-425
FITEM,2,446
FITEM,2,-447
FITEM,2,468
FITEM,2,-469
FITEM,2,518
FITEM,2,-519
FITEM,2,760
FITEM,2,-913
FITEM,2,4942
FITEM,2,-4943
FITEM,2,4964
FITEM,2,-4967
FITEM,2,5008
FITEM,2,-5009
FITEM,2,5030
FITEM,2,-5033
FITEM,2,5074
FITEM,2,-5075
FITEM,2,5096
FITEM,2,-5099
FITEM,2,6160
FITEM,2,-6161
FITEM,2,6182
FITEM,2,-6185
FITEM,2,6886
FITEM,2,-7347
D,P51X,UZ,1.0
ALLSEL,ALL
ESEL,U,TYPE,,1
PFACT,1,BASE,
PSDRES,DISP,REL
PSDRES,VELO,REL
PSDRES,ACEL,REL
/STATUS,SOLU
SOLVE
PSDCOM,0,15,
/STATUS,SOLU
SOLVE
 楼主| 发表于 2011-8-10 21:18 | 显示全部楼层
回复 1 # wangzhanghui 的帖子
那位大哥大姐可以帮忙看看啊~怎么解决这个问题呢~将PLANE42进行求解就会导致模态的错误,也是不可行的
GMT+8, 2025-1-27 04:24 , Processed in 0.074088 second(s), 17 queries , Gzip On.
