查看: 8109|回复: 6
[综合讨论] 进行谐响应分析后,出现load set not found on result file file
发表于 2011-7-5 22:59 | 显示全部楼层 |阅读模式
我用论坛的那个转换程序,每次运行会出现一个错误提示
load set not found on result file file.rst  为什么呢,请指点一下
/units,si
/PREP7
ET,1,SHELL63
R,1,0.00625
MP,EX,1,2.1E11
MP,DENS,1,7.8E3
MP,NUXY,1,0.3
K,1,,0
K,2,0.44,0
KGEN,2,1,2,1,,0.94
L,1,3
L,2,4
LESIZE,ALL,,,10
A,1,2,4,3
ESIZE,,10
AMESH,1
/SOLU
LPLOT, All
dl,2,,uz                       dl,2,,Rotx
dl,4,,uz                       dl,4,,Roty
dl,1,,ux                      dl,1,,Roty
dl,3,,uy                      dl,3,,Rotx
!MODAL ANALYSIS
ANTYPE,MODAL
MODOPT,LANB,10
SOLVE
FINISH
/SOLU
ANTYPE,HARMIC       ! HARMONIC RESPONSE ANALYSIS
HROPT,MSUP,6        ! MODE SUPERPOSITION
HROUT,OFF           ! AMPLITUDE, PHASE ANGLE PRINTOUT
F,45,FZ,100          ! FORCE AT X=.1657, NEAR QUARTER POINT
                    ! F, NODE, Lab, VALUE, VALUE2, NEND, NINC
                    ! Specifies force loads at nodes.
HARFRQ,10,1000        !  Defines the frequency range in the harmonic response analysis.
OUTPR,,NONE
OUTRES,,1
SOLVE
FINISH
/post1
freqe=1000
freqb=10
df=100
nfreq=(freqe-freqb)/df+1  !freqb,freqe,df分别为导出结果的起始频率、截止频率和频率间隔。
*get,nnod,node,,count     !把当前选择的节点总数读出,存到nnod
*dim,r,array,nnod,7,nfreq !建立r数组存储节点结果
*do,i,1,nfreq,1
  set,,i                   !读出第i个频率结果的实部
  *get,nd,node,,num,min    !读出当前最小节点编号,赋给nmin
  *do,j,1,nnod,1
    r(j,1,i)=nd
    r(j,2,i)=ux(nd)
    r(j,4,i)=uy(nd)
    r(j,6,i)=uz(nd)
    nd=ndnext(nd)
  *enddo
  set,,i,,1               !读出第i个频率结果的虚部
  *do,j,1,nnod,1
    r(j,3,i)=ux(nd)
    r(j,5,i)=uy(nd)
    r(j,7,i)=uz(nd)
    nd=ndnext(nd)
  *enddo
*enddo
*cfopen,result,fre
*do,i,1,nfreq,1               !freqb,freqe分别为结果起始频率和截止频率
  *vwrite,'SYSNOISE',' DISPLAC','EMENTS','FILE'
  (a,a,a7,a4)
  *vwrite,'Rev 5.5 ','IBM P2ES','SL 20-AP','R-04'
  (a,a,a,a4)
  *vwrite,'Displace','_Structu','re'
  (a,a,a2)
  *vwrite,' 20-APR-','2004 10:','07:13'
  (a,a,a5)
  *vwrite,'FREQUENC','Y'
  (a,a1)
  freq=freqb+(i-1)*df               !freq为当前存储频率
  *vwrite,freq
  (e20.8)
  *vwrite,'NODAL DI','SPLACEME','NT VALUE','S'
  (a,a,a,a1)
  *do,j,1,nnod,1
    nseq=chrval(j)       !将序号转换成字符,便于输出
    a=r(j,1,i)           !取节点编号值
    nd=chrval(a)         !将节点编号值转换成字符,便于输出
    uxr=r(j,2,i)         !取x方向实部到uxr
    uxi=r(j,3,i)         !取x方向虚部到uxr
    uyr=r(j,4,i)         !取y方向实部到uxr
    uyi=r(j,5,i)         !取y方向虚部到uxr
    uzr=r(j,6,i)         !取z方向实部到uxr
    uzi=r(j,7,i)         !取z方向虚部到uxr
    *vwrite,'  ',nseq,'  ',nd,uxr,uxi,uyr
    (a2,a8,a2,a8,e20.8,e20.8,e20.8)
    *vwrite,'','','',uyi,uzr,uzi
    (a8,a8,a4,e20.8,e20.8,e20.8)
    *vwrite,'','','',0,0,0
  *enddo
*enddo
*cfclos
FINISH
发表于 2011-11-24 21:14 | 显示全部楼层
楼主解决了没有啊
发表于 2012-4-22 20:15 | 显示全部楼层
回复 2 # tj591992034 的帖子
同问,有木有解决了啊
发表于 2012-7-2 15:24 | 显示全部楼层
问题在于:无法加载频率的虚部.
发表于 2012-7-2 16:47 | 显示全部楼层
另外, 貌似HROPT,MSUP,6        ! MODE SUPERPOSITION
不能提取频率的虚部?
如果改成hropt,full,不出去load...提示,*status,r查看结果,但频率的虚部还是没有加上去
发表于 2012-9-3 15:19 | 显示全部楼层
那应该怎么办呀?
set,,i,,1    这句应该怎么改?没有虚部去掉行吗?
发表于 2012-9-16 09:43 | 显示全部楼层
下面的代码没有出现楼主的问题.
finish$/clear
/filname,online-1,1
/units,si
/PREP7
ET,1,SHELL63
R,1,0.00625
MP,EX,1,2.1E11$MP,DENS,1,7.8E3$MP,NUXY,1,0.3
K,1,,0  $K,2,0.44,0
KGEN,2,1,2,1,,0.94
L,1,3   $L,2,4
LESIZE,ALL,,,10
A,1,2,4,3
ESIZE,,10
AMESH,1
LPLOT, All
dl,2,,uz  $dl,2,,Rotx
dl,4,,uz  $dl,4,,Roty
dl,1,,ux  $dl,1,,Roty
dl,3,,uy  $dl,3,,Rotx
!MODAL ANALYSIS
/SOLU
ANTYPE,MODAL
MODOPT,LANB,10!$mxpand,10,,,YES
SOLVE$FINISH
/SOLU
hropt,full
nsubst,100
OUTPR,,NONE
OUTRES,,1
SOLVE$FINISH
/post1
freqb=10
freqe=1000
df=100
*dim,r,array,nnod,7,nfreq !建立r数组存储节点结果 [121*7*11(行*列*页)]
*do,i,1,nfreq,1
  *do,j,1,nnod,1
    r(j,1,i)=nd
    r(j,2,i)=ux(nd)
    r(j,4,i)=uy(nd)
    r(j,6,i)=uz(nd)
    nd=ndnext(nd)
  *enddo
  *do,j,1,nnod,1
    r(j,3,i)=ux(nd)
    r(j,5,i)=uy(nd)
    r(j,7,i)=uz(nd)
    nd=ndnext(nd)
  *enddo
*enddo
*cfopen,result,fre
  (a,a,a7,a4)
  (a,a,a,a4)
  (a,a,a2)
  (a,a,a5)
  (a,a1)
  *vwrite,freq
  (e20.8)
  (a,a,a,a1)
  *do,j,1,nnod,1
    a=r(j,1,i)           !取节点编号值
  *enddo
*enddo
*cfclos
FINISH
GMT+8, 2025-1-10 16:05 , Processed in 0.069350 second(s), 17 queries , Gzip On.
