查看: 1828|回复: 1
[Virtual.Lab] ansys谐响应分析导入sys的奇怪问题
发表于 2011-6-25 01:47 | 显示全部楼层 |阅读模式
我用论坛的那个转换程序,每次运行会出现一个错误提示
load set not found on result file file.rst  为什么呢,请指点一下
/units,si
/PREP7
ET,1,SHELL63
R,1,0.00625
MP,EX,1,2.1E11
MP,DENS,1,7.8E3
MP,NUXY,1,0.3
K,1,,0
K,2,0.44,0
KGEN,2,1,2,1,,0.94
L,1,3
L,2,4
LESIZE,ALL,,,10
A,1,2,4,3
ESIZE,,10
AMESH,1
/SOLU
LPLOT, All
dl,2,,uz                       dl,2,,Rotx
dl,4,,uz                       dl,4,,Roty
dl,1,,ux                      dl,1,,Roty
dl,3,,uy                      dl,3,,Rotx
!MODAL ANALYSIS
ANTYPE,MODAL
MODOPT,LANB,10
SOLVE
FINISH
/SOLU
ANTYPE,HARMIC       ! HARMONIC RESPONSE ANALYSIS
HROPT,MSUP,6        ! MODE SUPERPOSITION
HROUT,OFF           ! AMPLITUDE, PHASE ANGLE PRINTOUT
F,45,FZ,100          ! FORCE AT X=.1657, NEAR QUARTER POINT
                    ! F, NODE, Lab, VALUE, VALUE2, NEND, NINC
                    ! Specifies force loads at nodes.
HARFRQ,10,1000        !  Defines the frequency range in the harmonic response analysis.
OUTPR,,NONE
OUTRES,,1
SOLVE
FINISH
/post1
freqe=1000
freqb=10
df=100
nfreq=(freqe-freqb)/df+1  !freqb,freqe,df分别为导出结果的起始频率、截止频率和频率间隔。
*get,nnod,node,,count     !把当前选择的节点总数读出,存到nnod
*dim,r,array,nnod,7,nfreq !建立r数组存储节点结果
*do,i,1,nfreq,1
  set,,i                   !读出第i个频率结果的实部
  *get,nd,node,,num,min    !读出当前最小节点编号,赋给nmin
  *do,j,1,nnod,1
    r(j,1,i)=nd
    r(j,2,i)=ux(nd)
    r(j,4,i)=uy(nd)
    r(j,6,i)=uz(nd)
    nd=ndnext(nd)
  *enddo
  set,,i,,1               !读出第i个频率结果的虚部
  *do,j,1,nnod,1
    r(j,3,i)=ux(nd)
    r(j,5,i)=uy(nd)
    r(j,7,i)=uz(nd)
    nd=ndnext(nd)
  *enddo
*enddo
*cfopen,result,fre
*do,i,1,nfreq,1               !freqb,freqe分别为结果起始频率和截止频率
  *vwrite,'SYSNOISE',' DISPLAC','EMENTS','FILE'
  (a,a,a7,a4)
  *vwrite,'Rev 5.5 ','IBM P2ES','SL 20-AP','R-04'
  (a,a,a,a4)
  *vwrite,'Displace','_Structu','re'
  (a,a,a2)
  *vwrite,' 20-APR-','2004 10:','07:13'
  (a,a,a5)
  *vwrite,'FREQUENC','Y'
  (a,a1)
  freq=freqb+(i-1)*df               !freq为当前存储频率
  *vwrite,freq
  (e20.8)
  *vwrite,'NODAL DI','SPLACEME','NT VALUE','S'
  (a,a,a,a1)
  *do,j,1,nnod,1
    nseq=chrval(j)       !将序号转换成字符,便于输出
    a=r(j,1,i)           !取节点编号值
    nd=chrval(a)         !将节点编号值转换成字符,便于输出
    uxr=r(j,2,i)         !取x方向实部到uxr
    uxi=r(j,3,i)         !取x方向虚部到uxr
    uyr=r(j,4,i)         !取y方向实部到uxr
    uyi=r(j,5,i)         !取y方向虚部到uxr
    uzr=r(j,6,i)         !取z方向实部到uxr
    uzi=r(j,7,i)         !取z方向虚部到uxr
    *vwrite,'  ',nseq,'  ',nd,uxr,uxi,uyr
    (a2,a8,a2,a8,e20.8,e20.8,e20.8)
    *vwrite,'','','',uyi,uzr,uzi
    (a8,a8,a4,e20.8,e20.8,e20.8)
    *vwrite,'','','',0,0,0
  *enddo
*enddo
*cfclos
FINISH
发表于 2012-3-10 22:10 | 显示全部楼层
回复 1 # wusemm 的帖子
同问啊 请问有知道如何解决的么
GMT+8, 2025-1-26 07:19 , Processed in 0.087741 second(s), 17 queries , Gzip On.
