查看: 1705|回复: 0
[Workbench] 进阶尺寸大小功能控制???
发表于 2011-6-9 12:11 | 显示全部楼层 |阅读模式
Note:
The Advanced Size Function controls are passed to the Patch Independent Tetrahedron method. That is, the Patch Independent Tetrahedron method does not use the same Advanced Size Function algorithms; rather, this method interprets the ontrols and uses internal algorithms to respect the user settings.
The General Sweep, Thin Sweep, and Hex Dominant mesh methods use the Advanced Size Function in the creation of the surface mesh, but the volume mesh does not use them.
进阶尺寸大小功能控制 准许 修补独立的四面体方式。
也就是说,修补独立的四面体方式并不使用相同的进阶尺寸大小功能演算法;
虽然翻译出来但还是不大懂它的意思? 请大侠解释一下.....
GMT+8, 2025-1-11 10:15 , Processed in 0.075047 second(s), 17 queries , Gzip On.
