查看: 2701|回复: 1
[其它软件] matcont的使用,谁会???
发表于 2011-5-28 21:46 | 显示全部楼层 |阅读模式
装完之后,出现如下情况:
>> matcont
??? Error: File: gui_EP.m Line: 939 Column: 12
"v" previously appeared to be used as a function or command, conflicting with its use here as the name of a variable.
A possible cause of this error is that you forgot to initialize the
variable, or you have initialized it implicitly using load or eval.
Error in ==> matcont at 83
        load(file);
反对: 3.0
反对: 3
repeat!! http://www.chinavib.com/thread-103177-1-1.html  发表于 2011-5-28 23:49
发表于 2011-9-11 22:21 | 显示全部楼层
是不是matlab中没有将变量定义清除,用clear all后在安装一下matcont。
GMT+8, 2024-12-27 21:08 , Processed in 0.097653 second(s), 18 queries , Gzip On.
