查看: 2116|回复: 1
[结构分析] 这边的 Function 意思是 功能 还是 函数 ????
发表于 2011-5-23 01:34 | 显示全部楼层 |阅读模式
Use Advanced Size Function
The Use Advanced Size Function option provides greater control over sizing functions. Advanced size functions control the following properties:
* Angles between normals for adjacent mesh elements (curvature-type size functions)
* Number of mesh elements employed in the gaps between two geometric entities (proximity-type size function)
* Gradation between minimum and maximum sizes based on a specified growth rate (all size functions)
Options for Use Advanced Size Function are Off, On: Proximity and Curvature, On: Proximity, On: Curvature and On: Fixed. The default is Off, unless Physics Preference is set to CFD, in which case the default is On: Curvature. The option you choose determines which refinement mechanisms are activated in the Advanced Size Function, as described in the following sections.
Controls that are common to all types of advanced size function include Min Size, Max Face Size, Max Size, and Growth Rate. The Min Size and Max Size specifications represent, respectively, the global minimum and global maximum allowable element size. The Max Face Size specification represents the global maximum allowable size of the elements created by the free surface meshers of the supported methods. The Growth Rate represents the increase in element edge length with each succeeding layer of elements from the edge or face. For example, a growth rate of 1.2 results in a 20% increase in element edge length with each succeeding layer of elements.
发表于 2011-5-23 12:20 | 显示全部楼层
应该翻译为“功能”,“Use Advanced Size Function”在这里是当一个名词在用,表示ANSYS中的某个特定功能,而不是APDL中的某个函数(再说,即便此功能有对应的APDL命令,那也应该不是APDL函数,APDL中函数和命令的指称是不同的,E是命令,sin()是函数)。因此,“The Use Advanced Size Function option”或许可以译为【使用“高级尺寸划分功能”选项...】
赞成: 5.0
赞成: 5
  发表于 2011-5-23 12:30
GMT+8, 2025-1-11 10:01 , Processed in 0.056449 second(s), 18 queries , Gzip On.
